32 tail lights gun metal grey L & R perfect condition SOLD
32 GTR front indicators L & R orange perfect SOLD
32 GTR Bonnet (Gun metal grey) SOLD
32 GTR ABS SOLD
32 glove box $30
32 GTR rear spoiler $175
32 GTR standard cooler piping SOLD
32 GTR speedo cluster $145
32 GTR centre guages $90
32 sun visors $35 pr
32 GTR windscreen wipers $30 pr
32 GTR windscreen wiper motor $40
32 GTR windscreen washer bottle with two motors $40
HKS air filters(2) with attachments that have sensors(suit GTR) SOLD
32 driver side electric window control SOLD
32 GTR oil catch can SOLD
32 GTR engine bay fuse cover $10
32 plastic piece that sits under the steering wheel, with driver side a/c vent $40
pm me for more details
located in sydney
parts not needed
for pics please send email ([email protected])
REASONABLE OFFERS WILL NOT BE REFUSED
Edited by DANSR33
https://www.sau.com.au/forums/topic/104275-cheap-r32-bits-and-pieces/
  • Replies 53
can you send a pic of the centre gauges i am interested...my email. is [email protected]
Ill try and get a pic to you soon, cameras dead....
u got the centre and passenger aircon vents by any chance? also any1 know of sum1 who mite wana sell a gtr grill?
Sorry mate but no and no
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
