Hey guys/girls....
i have a set of side skirts to suit an r33 gtst. these skirts are based on the 400r skirts but have a very unique feature.... see for urself :)
i recently bought these to fit to my car, but have since changed my plans, they are brand new, never used and are already in primer, so just need to be sanded and sprayed....
i am after $260 pretty firm, this is a good price.... oh and i have already trial fitted them they fit pretty good....
Price and Payment Conditions: $260 firm
Contact Details: 0422831920 or pm
Picture:
cheers
Mass
Edited by mass_iv
https://www.sau.com.au/forums/topic/104285-r33-gtst-400r-style-side-skirts/
Hey guys/girls....
i have a set of side skirts to suit an r33 gtst. these skirts are based on the 400r skirts but have a very unique feature.... see for urself :D
Not selling your front bar by any chance are you? I like the skirts but not the "Skyline" imprint, too hard to keep clean i reckon... maybe this could be filled or something?
you say that they fit FAIRLY WELL. so they not gonna be a perfect fit for a r33 gtst s1.5 1995????
wen i said fit fairly well, i meant that for fibre glass side skirts, they are a good fit... some kits dont fit good and others fit good, these fit nicely :P
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
