What To Do Tnite
  • Replies 86
oopz...
i just met this guy drives a black supra...look so sick
so i cant stop wasting my films on it as usual
mm....blackburn macas is a good place to catch nice cars.....
seriously if the guy whose after me the colour of the supra is not red...may gain more impression from me LOL:)
mm...supra vs. skylines.....who win??
what about a supra with twin turbo?
,,,my fren wanted to change it
he crashed a silver supra
now got a black supra...non turbo<---but can tail gts-t and twin turbo supra@@!!
and he wanna change to a twin turbo white supra....
he is so obsessed with it i assume
he was gonna drag with me last nite...but me SCARE of supras so NO NO...and i dont usually drag for nothing~_~
milk that friend of yours wouldnt happen to be warren would it??
if so we all went out friday night for valentines dinner
he let my friend jayde drive his supra and i drove his mates white TT supra down chaps
hehee
such laps we did!!
such greasies from marias we copped!!
ahaah
suchh drags we had had every light!! loll
and the boys just sat there and let us have our fun!
loll
was classss!!!
hehee
such laps we did!!
ahaah
loll
was classss!!!
hmm who was saying she doesent hang a chaps in another thread a few days ago???
He let u drive his car?? he must be really stupid or really like u!!
(So whens he getting his new gearbox and clutch) :)
lol denham
hehee he turned the traction control off
omggg
suchhhh funnnnnnnn
mmm wheel spin
i was so tempted to just smack second and take it sideways
heheh
but i tried my best to behave
but he was the one telling me to floor it
ohhh the sound of turbo spooll
mmm such magicccc
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
