What To Do Tnite
  • Replies 86
oopz...
i just met this guy drives a black supra...look so sick
so i cant stop wasting my films on it as usual
mm....blackburn macas is a good place to catch nice cars.....
seriously if the guy whose after me the colour of the supra is not red...may gain more impression from me LOL:)
mm...supra vs. skylines.....who win??
what about a supra with twin turbo?
,,,my fren wanted to change it
he crashed a silver supra
now got a black supra...non turbo<---but can tail gts-t and twin turbo supra@@!!
and he wanna change to a twin turbo white supra....
he is so obsessed with it i assume
he was gonna drag with me last nite...but me SCARE of supras so NO NO...and i dont usually drag for nothing~_~
milk that friend of yours wouldnt happen to be warren would it??
if so we all went out friday night for valentines dinner
he let my friend jayde drive his supra and i drove his mates white TT supra down chaps
hehee
such laps we did!!
such greasies from marias we copped!!
ahaah
suchh drags we had had every light!! loll
and the boys just sat there and let us have our fun!
loll
was classss!!!
hehee
such laps we did!!
ahaah
loll
was classss!!!
hmm who was saying she doesent hang a chaps in another thread a few days ago???
He let u drive his car?? he must be really stupid or really like u!!
(So whens he getting his new gearbox and clutch) :)
lol denham
hehee he turned the traction control off
omggg
suchhhh funnnnnnnn
mmm wheel spin
i was so tempted to just smack second and take it sideways
heheh
but i tried my best to behave
but he was the one telling me to floor it
ohhh the sound of turbo spooll
mmm such magicccc
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
