Hey check out ebay au, happen to see a post of NGK G-Power platinum going for $5 buck with free shipping..
NGK G-Power
Another interesting thing to note, for R32 owners etc... the coil pack PLUGS (loom side), have a tendency to DESINTEGRATE... especially if they're 13-15 years old... I've seen this happen before, and today I changed my plugs (after having missing on 2 cylinders... sounded like a WRX :D) to copper BCPR6ES-11's gapped to 0.7mm, and had TWO stuffed coilpack plugs. She runs a charm now.
Even if the inside yellow/brown section of the coilpack plug desintegrates, DONT cut the plug off... you CAN NOT buy these new (as far as i know), and will have to source them off another wreck. They still work fine if the yellow/brown plastic comes out, just push the pins/resitors back in, and connect the plug carefully... no dramas! :)
i iused the BCPR6ES and had major missfire problems under boost which then killed the plugs so it sounded like scooby. i then replaced them with BCPR7ES and all is well. i have an R32 gts-t std boost but HKS air filter, exhaust including downpipe with bov.
Im in england by the way.
Thanks John
With regards to the V-Power.
They are a little difficult to get here in SA but I have found Motortraders stock the BCPR6E.
The BCPR6E are the V-power/groove plug. I believe they dropped the Y.
From memory a set of 6 from Motortraders is around $17.
Don't bother with supercrap they wanted 3x the price.
Dirt Cheap. :D
They are..
I've been running them since they were called BCPR6EY. Around 2-3years ago for some reason they dropped the Y.
So in total including the Y's I have been running them since I bought the car 4.5yrs ago.
I have an old spark plug laying around somewhere, I'll grab a pic of it and post her up.
But as I said the only place that stocks them is Motortraders, specifically Motortraders at Edwardstown. The BCPR6E-11's appear to be a little more abundant.
Here's a quick google result.
http://www.overboost.com/obs/hin/product.a...name=Sparkplugs
and this from an old NGK link.
http://66.102.7.104/search?q=cache:sSDfG7y...lient=firefox-a
I gave them a buzz as Im going to throw in a set of 7's in a couple of weeks.
Unfortunately they don't have the BCPR7E/BCPR7E-11 or BKR7E/BKR7E-11 listed, the BCPR6E's are.
Bugger..
EDIT: And a couple pics of the BCPR6E that have done 30,000km's.
They were still running fine in the car but you can see they were on their way out as the electrode is well and truley rounded. :whistling:
No octane boosters and the like only ever BP98.
Sweet. Good stuff they have the BCPR7E then!
And yeah those sparkies look well and truely shagged. Lucky their cheap!
What gap are you running? I've found I can gap V-Powers around 0.1 - 0.15 bigger than NGK Platinums which is a testimony to their efficiency.
Yeah actually come to think of it, I've never been able to get my hands on the 0.8mm version. Always the BKR7E-11. Kinda annoying. The guys in the States debate about gapping the -11s down to 0.8mm (or less) as they say the electrode isnt parallel anymore. Still works good though..
I've noticed this also when I gapped a set down, which is why until now I've avoided gapping down.
Couldnt you guys just order in a whole bunch, group buy it on here or something?
Im going to try and find them tomorrow tho, and do it on the weekend see how it goes and all.
Quick question tho. If my little sprung coilpack contact things are gone, but the coilpack other than that is still good, what would I use as a replacement for the spring?
Well my worst fears are confirmed, 3 of 3 coil packs I pulled out had cracks and tested at the 20k ohms setting 1.5,1.6 and 1.7, I have allready found some new ones at Kudos motorsport, has anyone bought from them and these are OEM units.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
