Well I had a heap of fun, and I hope you all did too! There were about 3 people that came without RC's because they'd broken them... oh well! Next time!
Everyone seemed pretty happy with the location, even though it was a bit of a drive for some. It is out of the way, noone complains, and noone will ask us to move on.
This, and qwux has a small supply of track-making equipment (along with my newfound collection of nursery plant pots), which makes it much better than just freestyle drifting.
Someone took photos, so i'm sure they will put them up, and the video will be up in a little while! (on the SRCD forums)
Future RC drifting will be announced on the SRCD forums, and not on SAU, so be sure to sign up if you're keen for the next one!
  • Replies 158
Posted Images
Yeah, this meet was very good I must say... nice to see members organizing stuff outside of the usual circle of things ;)
Sorry I couldn't stay, as mentioned, just started a new business and had to attend to that. Will make more of an effort for the next meet :(
OK; after going to this meet and speaking with a few mates I've decided to invest some pennies in a new RC car ;)
HPI RS4 Evo3 - Base Car
Stage D Kit - Turns Base Car into Drift King
I can't believe I'm going to spend $800 on a toy!
Disappointed... went into Hobbyco in the city and told them I wanted not 1 but 3 of the same kits! They said they sold out about 2 weeks ago!!!
And get this, to bring them in from the states, it's going to cost me $150 more each!!!! f**k THAT!
Damn Americans and their expensive overatted products! But you guys have to go watch that video on their site, it'll make anyone want this toy car!
good day. great fun
dingo again sorry bout your car, but remeber i wasnt driving it then.
hahahah I dont blame anyone but me for the crash. My cars a p.o.s anyhow. Next event ill just put maccas trays under the rear wheels of the charade :lol:
OK; after going to this meet and speaking with a few mates I've decided to invest some pennies in a new RC car :P
Try Rc hobbies on Parra road at Petersham. They stock alot of HPI stuff and are a bit cheaper that HobbyCo. Or just order direct from their site www.rchobbies.com.au.
  • 4 weeks later...
Guys, yes, we still do meets, and it's all organised on the SRCD forums:
http://srandy.com:82
That URL is temporary until the proper domain name is usable.
Meets, and RC drift discussion happens here.
We were in Bankstown two weeks ago!
Next meet will probably be on the Northern Beaches, then somewhere halfway between Bankstown and the NB.
We're also looking at doing an event at Windsor RC track, and possibly entering in this years AutoSalon RC drift.
Check our forums!
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
