I Dont ***in Believe It
  • Replies 129
Originally posted by INASNT
sidways
i am gonna put the stock cat back system back on for the test and then take it off!
when u going in? i am going in on tuesday 1pm
Thursday is my test...
I don't have the stock system - mine didn't have one when I bought it... so I will have to go for the new muffler....
DJ_L3ThAL: depends where you go. My car is similar in specs to Inasnt's and i have yet (cross fingers, tempt fate, pray to god) to be pulled over. It depends on the area as to how vigilent they are. If they have to put up with idiots all day in imports (hopefulyl none of us guys) then i can imagine it annoys them. Just travelling to the outer suburbs i see bad driving in imports and bad attitude so i can kinda understand sometimes.
If anything I'd say the city would be one of the safer places, as its a hassle to pull someone over during peak hour just to check for roadworthiness. It will just end up holding up traffic and creating huge traffic congestion.
Do nothing wrong, have no obvious signs your car isn't too crazy and (most) of the time they won't pull you over. Just be very careful in your exhaust selection to make sure it doesn't come near 90db.
There is no reason why a 250rwkw car has to be any more noiser or faster looking than a bog standard 130rwkw one. Unless you dump the foot at every set of lights and/or rev the tits off it, a cop isn't going to be any wiser.
That could unfortunately be true - that would suck extra as well!
You need some tinted windows so they can't tell whether you're dark, white, or green :)...hmmm then they'd probably get you for that too, Nobody can win. I'll probably get done one day anyway, so far I've probably just been lucky.
Thing is their goal is to double revenue this year on the roads (not sure exactly where I read it, but I'm definitely sure I did read it earlier in the year), and they'll do whatever dirty methods they can to get there.
I am sure if I was in a different suburb to rich-trash land things would be equally bad for me.
hmm, oh well, my car looks bog stock from the outside except for the lights of which ill change tonight when i install my boost gauge, and im going to keep it that way, big kits and spoilers just dont do it for me for some reason, i dont like srawing attention, the only reason i got the lights was coz i was cut with the stock yellowish ones, but i got proper white white ones today :P
and predator i finally fixed my light covers, got some nice cut n polish and they look as good as new, im so happy now, also i fixed some of the cars scratches, will do the rest on saturday so she's nice n beautiful :D
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
