I Dont ***in Believe It
  • Replies 129
yo inasnt, if you need a car to smash into the cops house, you can use my VN ifn ya want
feel for ya man, ya cant do shi.t though cause ppl voted in that Bracks jerkoff and we cant do shi.t till the next election
maybe you need to stalk bracksy......
hey now theres an idea
bwuhahahahaha:)
Guest INASNT
update
just came back from the epa test.
about 15 mins and i was on my way.
They looked in the engine bay, under the car, in the interior check that the afm was working and the stock boost controller was connnected, did their polution test and noise test. I recorded 83 db.
Guys there are preety nice and said i wont be asked to come back again unless the cops provide some sort of evidence that my exhaust has been changed.
When i was pulling out a MY01 Sti WRX was pulling in, they have been targeting skylines and wrx's recently!
Now time to put all my stuff back on.
My car is so quiet with the stock exhaust and air box, sometimes at the lights i have to check if the car was actually on. :P
hey u ain't got 185rwkw now...liar!!! for now...D
Denham I saw u the other day sat morning u were at chandler & heatherton rd. intersection, was gonna wave but u would've thought, who's the freak in the 120y chugin along....:P she puts the power down real well got traction thru all gears, she's tip top!! :D
haha I'm surprised its still in one peice with all the bog....man she's a real work horse, it carried two trannies 1 in boot and 1 in rear seat mate she still body rolled with all that weight and it was like dumped off its tits.... :P
Guest INASNT
i had to drive around a 120y as a courtasy car once when my old car was being repaired. I had to use a pair of plyers to hold the choke open for about 10 mins in the morning or otherwise it would run properly! doing 100km/h in that thing felt like about 250km/h in a normal car :P
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
