I Dont ***in Believe It
  • Replies 129
yo inasnt, if you need a car to smash into the cops house, you can use my VN ifn ya want
feel for ya man, ya cant do shi.t though cause ppl voted in that Bracks jerkoff and we cant do shi.t till the next election
maybe you need to stalk bracksy......
hey now theres an idea
bwuhahahahaha:)
Guest INASNT
update
just came back from the epa test.
about 15 mins and i was on my way.
They looked in the engine bay, under the car, in the interior check that the afm was working and the stock boost controller was connnected, did their polution test and noise test. I recorded 83 db.
Guys there are preety nice and said i wont be asked to come back again unless the cops provide some sort of evidence that my exhaust has been changed.
When i was pulling out a MY01 Sti WRX was pulling in, they have been targeting skylines and wrx's recently!
Now time to put all my stuff back on.
My car is so quiet with the stock exhaust and air box, sometimes at the lights i have to check if the car was actually on. :P
hey u ain't got 185rwkw now...liar!!! for now...D
Denham I saw u the other day sat morning u were at chandler & heatherton rd. intersection, was gonna wave but u would've thought, who's the freak in the 120y chugin along....:P she puts the power down real well got traction thru all gears, she's tip top!! :D
haha I'm surprised its still in one peice with all the bog....man she's a real work horse, it carried two trannies 1 in boot and 1 in rear seat mate she still body rolled with all that weight and it was like dumped off its tits.... :P
Guest INASNT
i had to drive around a 120y as a courtasy car once when my old car was being repaired. I had to use a pair of plyers to hold the choke open for about 10 mins in the morning or otherwise it would run properly! doing 100km/h in that thing felt like about 250km/h in a normal car :P
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
