I Dont ***in Believe It
  • Replies 129
yo inasnt, if you need a car to smash into the cops house, you can use my VN ifn ya want
feel for ya man, ya cant do shi.t though cause ppl voted in that Bracks jerkoff and we cant do shi.t till the next election
maybe you need to stalk bracksy......
hey now theres an idea
bwuhahahahaha:)
Guest INASNT
update
just came back from the epa test.
about 15 mins and i was on my way.
They looked in the engine bay, under the car, in the interior check that the afm was working and the stock boost controller was connnected, did their polution test and noise test. I recorded 83 db.
Guys there are preety nice and said i wont be asked to come back again unless the cops provide some sort of evidence that my exhaust has been changed.
When i was pulling out a MY01 Sti WRX was pulling in, they have been targeting skylines and wrx's recently!
Now time to put all my stuff back on.
My car is so quiet with the stock exhaust and air box, sometimes at the lights i have to check if the car was actually on. :P
hey u ain't got 185rwkw now...liar!!! for now...D
Denham I saw u the other day sat morning u were at chandler & heatherton rd. intersection, was gonna wave but u would've thought, who's the freak in the 120y chugin along....:P she puts the power down real well got traction thru all gears, she's tip top!! :D
haha I'm surprised its still in one peice with all the bog....man she's a real work horse, it carried two trannies 1 in boot and 1 in rear seat mate she still body rolled with all that weight and it was like dumped off its tits.... :P
Guest INASNT
i had to drive around a 120y as a courtasy car once when my old car was being repaired. I had to use a pair of plyers to hold the choke open for about 10 mins in the morning or otherwise it would run properly! doing 100km/h in that thing felt like about 250km/h in a normal car :P
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
