Look out
Guest andrewjread
lookout peoples! just went down the wharf today to check on my skyline and theres a heap of new skylines, supras, and 180sx. Some looked like they might well be heavily modified. I guess theres a rush on them before the changes. ANy of these cars belong to you people??
Somehow i got in the compound by driving right behind a car carrier truck, and the light goes green and the gate opens automatically on the way out. No one questioned me inside which is probably a bad thing.
Anyway, my car has been moved right to the waters edge at the end now since it is still there from the previous ship.
This is not good. Been sitting in direct sun and salt water atmosphere for the last ~2 months. Will this shorten the life span of the paint work?
WHERE THE @#$@#$ IS MY Approval god dam canberra @#$@#$'s
https://www.sau.com.au/forums/topic/10470-look-out/
andrewjread, I know someone who has a Supra, a couple of R33'S, GTR. The Canberra people only went back to work a couple of weeks ago, so they are up to their armpits in paperwork. Check every code on every form, because they are sending approval for the wrong models of cars, which is holding things up further.
It's annoying that you can't rush it, it must be costing you a fortune.
https://www.sau.com.au/forums/topic/10470-look-out/#findComment-167858
Guest andrewjread
I saw that orange 180sx when I was there. I think it might be a race car.
Spoke to the customs agent and the approval should be here next week. The car was sent it error and thats how I snapped up this bargain. I have not actually paid for the car and will not until approval comes across. I could foresee this happeninig and made alternative arrangements with Geoff. Will even get service fee back if approval rejected. I did not even apply for approval under my name as this could also endanger me to unwanted expenses. I think theses are the reasons why its taking so god dam long.
Anyone live around MT Lawley area and willing to take me for a spin in their skyline and give me some pointers. I have not even been in one have become obsessed with them...weird heh. There may well be some beverages involved for the willing participant.
Cheers,
Andrew
https://www.sau.com.au/forums/topic/10470-look-out/#findComment-167887
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
