hay mate you would have to contact garrett direct. i have only rebuilt them on trucks and we use a new cartridge and clean, blast and crack test the snails. unless you have the facilities to dynamically ballance the cartridge once you have assembled it is going to be a time bomb.
cheers,
boz
Hi,
I have a Hi-Flowed R33 GTS-T Turbo which has only minor bush wear - can anyone tell me where to obtain a Turbo Rebuild Kit  - bearings, seals, gaskets, thrust bearings etc
Thanks
cheers,
boz
I appreciate your comments - there is a great deal of debate on balancing - one way to balance the turbine wheel and shaft and compressor wheel as a single unit. The other way is to balance the turbine wheel and shaft and the compressor wheel individually. You can usually tell by the shape of the compressor nut. If the nut appaers to be ground down then the turbine wheel shaft and compressor wheel were balanced together. If the nut is not ground down but then are light grinding areas on the back of the compressor wheel, then it most likely that the wheels were balanced individually. If the wheels were ground individually then it is not necessary to assemble them in the same relative locations.
In my case this is how this turbo was balanced and has probably only done limited kms since it was hi-flowed. Many think that rebuilding a Turbo is overwhelming, but if you take your time, use common sense it is fairly easy.
You said to try Garret - where are they located??
Thanks Champ
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
