Ok on Saturday a group of us headed to Benaraby for a test and tune and the best results for the 3 Skys that ran are as follows...
Ricknismo (from SDU) White 4 door R 33 (with a boot ful of stereo gear :P ) JIC VERY HARD COILOVERS and 18's:
best ET 14.11
Dave Silver R33 2Door (as seen at QLD Skidpan Day this year and for sale if anyone is interested) On 17's and Ohlins suspension:
Best ET 13.7
Jeremy Silver R33 2door On R33 GTR wheels:
Best ET 12.99
on slicks
Best ET 12.27 (only got two runs on slicks and the other was a 12.28)
Squizz R32 Non-turbo
Best ET 00.00 car still at home cause I can't drive for another 30 days GOD DAMMIT I CAN'T COPE ANY MORE IT'S DRIVING ME INSANE!!!!!!!!!!!!!!!!!!
Oh, are sorry about that :D
https://www.sau.com.au/forums/topic/1049-benaraby-drag-results/
Good stuff guys, I love drag racing it rocks, I am actually going to get really involved in it.
You have highlighted the main problem with all our cars....the suspension setup. Its all good on the track/street, but on the strip it is way too hard. Get yourselves some stock stuff and go hard.
Nice run Dave, same as my car.
I should point out that it was Dave's first time to the drags also. He drove like a friggin champ all day - he had like ten runs, but my favourite was him spanking this worked 308 VK, looked sweet as to watch. I'll have to try and d/l the video when I get it. I'll find some pics of the cars though...
Nice numbers fellas :P
Especially Jeremy's silver R33, a 12.99 on road rubber, well done!.
Is his car a GTS25t? If so what's it had done? Any idea of the terminal speed on his runs?
Thanks :D
It's had a fair amount of work done. Going from what I remember from when we got it in it has...
It's a GTS-25t
Greddy Plenum
Aftermarket Turbo (needs a bigger one)
Power FC
HKS Cams
Bid Zorst
Front Mount
Blitz Boost control
Huge fuel pump
larger injectors
It's a f**king weapon.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
