OK, I need to draw on the collective experience on here! Put my car on a dyno this morning to try and diagnose a miss high in the revs. Anyway, the problem is that now the back of the car vibrates and almost bounces at speed. It was suggested at Chilleh tonight that the CV joints might be the culprit, but there is no vibration through the gearstick or steering wheel. All seat of the pants big-time vibration!
Could the dyno have spun the tyres and put out the balance so much as to cause the massive vibration??
Any suggestions are appreciated.
Dave
https://www.sau.com.au/forums/topic/104922-problem-with-my-line/
And the prize goes too................
No one!! Turns out one of the tyres was about to pop!! Being some cheap shite from assbang indonesia, they couldn't take our Aussie heat and there were 6 bulges on the inside of the tyre wall all about 4 cm's wide. So, 2 new tyres on the back and we will keep an eye on the front ones. Got some decent tyres this time, Firestone Firehawks. $500 for the two fitted and balanced so not too bad.
Have kept the old tyres as I may take them back as they were only 5 months old.
kwal-it-tee
i would be taking them back aswell, cheap arse p.o.s. may i ask what brand they were just so when i go to buy next time, i know what to steer clear of....
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
