Yes I know it's been done before but we have a problem with a bunch of new people joining the forums.
It's always better when we go on cruises etc if we know who's who.
Suggest putting up a pic of yourself and your real first name ( no yours is not psycho , psycho ) to make it easier when we go somewhere. Also cos I got the memory of a goldfish
* thinks , what was the title again *?
Will take some this morning of a couple of us and if you have a problem with posting the pics , send them to me
[email protected]
and I will onforward them to Skyzerrs crappy hotmail account.
Cheers
Ken
https://www.sau.com.au/forums/topic/10494-pics-and-nics-of-w-a-people/
  • Replies 341
Ok we will start the ball rolling ( and show the quality of Pics required ) by the following.
Troy ( Skyzerr33 ) is on the left and pwptf aka Paul aka GTS-t VSPEC is on the right.
R33 might not be whales but there drivers can be .:lol:
Cheers
( cheapshots )
Ken
Remember peoples ( ohh triple post )
If you complain that no one comes up and says hello at the cruises etc and you haven't posted a pic and your name , don't blame us.
Cheers
Ken
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
