Hello,
I would like to know the answer to this too.
What oil are you using at the moment?
Im pretty sure im using the wrong type, so i want to change it, im using redline light weight in it atm, because i had some left over from when i filled the gearbox, and its an absolute pain in the ass driving it around slow corners.
Ive done a search and the general suggestion is redline mt90 for diff's, but don't know if thats the best option for really tight diffs.
Cheers.
Interesting question, however I have a feeling you can't really do anything about it without taking the diff out and getting a diff specialist to look at it.
My advise is to go to a workshop that specialises in diff's and ask them what you can do. or find someone with a looser 2-way and do a swap.
Some diff's (eg Nismo) allow you to adjust how tight it is, but most diff's don't.
From my experience with different oils in my mech diff, you can't go past Castrol SAF-XA synthetic if you want a more street friendly diff. I found that other LSD oils (including Redline lightweight shockproof) make a tight mech very clunky.
I went through a long saga with mine including getting it pulled down and inspected / reshimmed, and the only thing that made it streetable was the Castrol oil.
Edited by krizza_ca18det
Bl4ck32 runs a nismo 2way adjustable.
I do remember some one suggesting to adjust a little tighter so that it doesn't disengage so easily around corners, obviously resulting in slight tyre squeel but at least there will be very little clunk. He has yet to adjust it, its currently on the loosest setting.
Let us know how the castrol performs. The clunkyness is the only thing putting myself off a mech. lsd.
I must agree with this, before i changed the oil in the diff to redline lightweight, the diff was definetly not as tight, loud and clunky, after i changed over and the oil was run in a little, the diff started to get very loud clunky and tight, with the tyres locking up and chirping while turning corners at intersections. I think i will give this Castrol SAF-XA synthetic a go.
well i took it for a lap arond the block a few times (20 times!) and it seemed to be a lot quieter than whats it was when i first got it, although i didnt do too many tight turns etc.
steve
Hello,
Hows the diff feeling and sounding 2 or so weeks down the track? Also what kind of tool and size did u use to unscrew the bolts? I went to change the oil but to my frustration i didn't have anything that i could use to unscrew them, i will have to go and buy some, and help appreciated.
Cheers!
SNG.
Hello,
Does anyone know if its alright to buy and use some sort of spray to loosen the filler and drain bolts? ive just about destroyed my tool, and bent the handle back and forth a few times and the bolt still refuses to budge, or will it contaminate the oil or loosen the bolt so it may work its way loose later down the track?
Thanks,
SNG.
Also to ask another pretty stupid obvious question, it is counter-clockwise to loosen correct?
Edited by SNG
Hello,
Just to give some feedback, changed the oil over today to the Castrol SAF-XA Synthetic, beautiful stuff, fixed my problems immediately, no more clunking at all nor shudder through the car or chirping of the wheels going thru corners, recommend giving it a shot if your having problems like i did.
SNG.
Hey guys,
Yeah it definitely worked in my case, but as i mentioned earlier above, i incorrectly had redline superlight weight gearbox oil in it so i don't know if that made it worse than it should have and consequently it seems alot better now than what im used to with it.
From memory i *think* it was around 20 bux a bottle of 1 litre roughly from auto one? (You will need about 2 litres) I don't know what type of diff i have, but when i had it on the hoist, when i turned the rear wheel one way, the opposing wheel turns the opposite way, and the diff itself looks aftermarket compared to my previous GTR, i was told that i had an mech diff.
It now almost feels like my last GTR which was stock, but i swear i can still kinda feel it giving resistance very minutely when going around corners.
I just wanted to give some feedback from my personal experience regarding this oil, it may work in your case, it may not.
Cheers!
SNG.
Chrylser make a rear diff oil additive for they call their Jeep Cherokee range, here in the UK (4wd 4x4). The plate type rear diff is poor in these, and tends to clunk and chatter (as well as the CWP wears out for fun...). Some people get really up tight about it and Chryler, like GM did in the 70's with the Corvette, came out with a friction additive for the diff oil. If you bung 2 bottles of it in a plate type diff it will often stop chattering and ratcheting, but a lot depends on the preload it's set to, and the style of the friction plates. Worth a go, it's not expensive over here, at least.
  • 1 month later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
