btw, west the pics in pm worked for me?
but i dont know if anyone needs the pics that badly. surely you can picture a rocker switch, a fuse, some wire and some terminals... this thing is all about its function though so maybe just picture a smokey burnout, then decide if that's what you want. if it is, buy one.
To all the people PMing me wanting detailed pics.....read above post.
You cannot produce these yourself for under $25.....not 1 off's......they are a professionally built item delivered to your door for $35.....don't be tight and spend an extra $10 to save you the hassle of production and have it delivered to your door with detailed instructions. Yes any auto electrician with 1/2 a brain can produce these, but for what cost (parts and labour).
Read the thread thouroughly and see all the happy customers.
  • Replies 419
Posted Images
Pretty keen on one, i take it they will be the same for R32 GTS4?
Did not see an answer to this in all the posts - but maybe I'm blind;-)
GTS4 needs to have underbonnet fuse pulled as well as fuse in under dash box, at least in mine anyway.
Does this unit cover this requirement?
Paul is away working. I'll get him to answer your question as soon as he can. Sorry for delayed answer TurboX.
Cheers
Stacey (DiRTgarge better half)
Also.......Paul will be making the 2nd batch on the weekend. So if you want one pls send your $$, banking details were supplied in the pm's. If you want one and I have forgotten to send you the details pls pm me........as its getting abit confusing.
So far I will be posting switches to: Weapon of Choice and Mr 32
Cheers Stace
Thats normal as the abs is off when 4wd is off, so be careful not to lock the brakes up
For all the good people waiting on looms....ive arrived back from trip away and will have them in your hands hopefully before the weekend.
Thats good news mate :laugh:
So whered u go for ya holliday?
Hi,
Just noticed I haven't been added to the list on the first page. Sent payment and mail address through last week, can you confirm if received yet?
Thanks
Stace was running the show last week and has failed to update main page...i assure you that all paid orders will be met by the end of the week....wannabeslida...you are one of them.
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
