btw, west the pics in pm worked for me?
but i dont know if anyone needs the pics that badly. surely you can picture a rocker switch, a fuse, some wire and some terminals... this thing is all about its function though so maybe just picture a smokey burnout, then decide if that's what you want. if it is, buy one.
To all the people PMing me wanting detailed pics.....read above post.
You cannot produce these yourself for under $25.....not 1 off's......they are a professionally built item delivered to your door for $35.....don't be tight and spend an extra $10 to save you the hassle of production and have it delivered to your door with detailed instructions. Yes any auto electrician with 1/2 a brain can produce these, but for what cost (parts and labour).
Read the thread thouroughly and see all the happy customers.
  • Replies 419
Posted Images
Pretty keen on one, i take it they will be the same for R32 GTS4?
Did not see an answer to this in all the posts - but maybe I'm blind;-)
GTS4 needs to have underbonnet fuse pulled as well as fuse in under dash box, at least in mine anyway.
Does this unit cover this requirement?
Paul is away working. I'll get him to answer your question as soon as he can. Sorry for delayed answer TurboX.
Cheers
Stacey (DiRTgarge better half)
Also.......Paul will be making the 2nd batch on the weekend. So if you want one pls send your $$, banking details were supplied in the pm's. If you want one and I have forgotten to send you the details pls pm me........as its getting abit confusing.
So far I will be posting switches to: Weapon of Choice and Mr 32
Cheers Stace
Thats normal as the abs is off when 4wd is off, so be careful not to lock the brakes up
For all the good people waiting on looms....ive arrived back from trip away and will have them in your hands hopefully before the weekend.
Thats good news mate :laugh:
So whered u go for ya holliday?
Hi,
Just noticed I haven't been added to the list on the first page. Sent payment and mail address through last week, can you confirm if received yet?
Thanks
Stace was running the show last week and has failed to update main page...i assure you that all paid orders will be met by the end of the week....wannabeslida...you are one of them.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
