Hey guys
I've got my gauges sitting in my room waiting to be installed, but i'm still deciding where and how i want to mount them.
at the moment i've got a dual gauge pillar mount...with a boost and oil pressure gauge.
changed my mind and decided i don't want to drill into the pillar to mount it and do the wiring etc....
So i'm thinking i'll sell the oil pressure gauge and the dual pillar mount (both brand new never been used) and either buy a single mount for the pillar, or the other option (which is what this thread is for) is to mount the boost gauge on top of the dash, in the corner of the windscreen....
Can you guys post up some pics of your boost gauge installs please....I want to see what kind of pods etc you've put them in, and how you've done your wiring/hoses etc...
Thanks :D
https://www.sau.com.au/forums/topic/105365-boost-gauges/
thanks for the pics mate
i know its not a life changing decision but im still undecided:P
i love the look of the pillar mounts...they look so factory when done properly...but at the same time i dont want to drill into it...maybe there's a way i can have a pillar mount without drilling, ill just have to figure out a way....otherwise ill mount it on top of the dash in a gauge cup....or maybe i could just buy a spare a pillar garnish to put on if i ever change my mind ....hmm
https://www.sau.com.au/forums/topic/105365-boost-gauges/#findComment-1962695
im pretty sure so long as its not above the height of the steering wheel its legal.. that means on the dash in the corner is fine.... and pillar mounts are illegal full stop, thats because it wud be hard to mount them low enough!!!
i was told this by a cop so i dunno if this is true or not... mine is a single pillar mount dezz, looks nice but i wudnt mind a double.... u only need a tiny hole to fit the diring and then 2 holes for the screws to secure the mount...
on 200sx's u can buy a whole pillar that comes with the mount as one piece, does anyone know if they make these for skylines???? if so where can i get one???? i dont like the screws showing on my pillar mount either..... wud look much better as a single unit..
https://www.sau.com.au/forums/topic/105365-boost-gauges/#findComment-1962995
sup guys. if i remember correctly, you can have a pillar mount gauge as long as it does not get in the way of the veiw of the windscreen. if that makes sense. i would check on vicroads and find the legal modifications list thing... but its hidden away a bit... (obviously this is for you dezz cos your from vic it seems). so you will have to take a search.
cheers. james.
https://www.sau.com.au/forums/topic/105365-boost-gauges/#findComment-1963466
Well the one I have on has caps covering the screws so its not really visible unless you look closely. Plus this Autometer range was designed to blend in R33 series interiors so they wont stand out once installed
https://www.sau.com.au/forums/topic/105365-boost-gauges/#findComment-1964061
If you want to install it without any damage or drilling... use the "wedge" formula ;)
Look in the DIY thread for my write up... I've moved it down further a bit since then and used a thicker foam, it's now solid as a rock as the foam actually grips onto the dash trim.
https://www.sau.com.au/forums/topic/105365-boost-gauges/#findComment-1967062
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
