Hey guys and gals, I'd appreciate your thoughts and oppinions on the colour of this 33.
While your at it, if you have any pics of colours you really like then post it up.
Really need some input.
I'd also really appreciate your thoughts on the colour of this Zed, although i think you will already say its to bling.....
https://www.sau.com.au/forums/topic/105463-what-do-we-think-of/
the R33 looks like some form of kandy apple red which is similar to my car.
IMO kandy red is one of the all time hottest colours and it has stood the test of time.
not like all these other shitty colours that come in and out within a year
the zed i think looks f*ked tooo much flake.
prime example of a colour that will come in and then be out before u know it.
i love the kandy red colour, but i guess the problem with it being a popular colour is that so many cars have it these days....that gold flake though is just gross
my favortie ever poaintjob ive seen was a falcon t the nats 2 years ago, silver with rainbow pearl/subtle flake through it, was over at the house of colour stand remember that one jayce?
also added some pics of cars with nice colours andy
Indeed, Candy Red really does seem to look amazing.
Are you able to post any pics of yours? I can't remember if you had your engine bay done alswell though? What did yours end up setting you back?
everything was stripped out of the car and it was all painted except inside the boot and cabin
i got it done at mates rates cause im good mates with Brian (MR WRX)
so he looked after me
Yeah the cost is a concern for me, I think I'd be lucky to get away with a full respray inc eng/door trims for $5,000 in Candy.
Oh, also, your master auto trim link in your sig is no longer valid, i think Loiue has changed srvers.
Indeed i think you're right about the cherry black, oh well i've been a big enough help to the ACT car community and particularly SAU i'm sure when the time comes someone will be able to find someone to help me out with a mates rates job.
In the mean time i have the luxury of choosing my paint, i might give J-Racing a call and see if they have a house of kolour catalogue.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
