Dont know if a lot of gtr's have 19s on them, i have 18's though if that helps??
What sort of rims are those?
They look hot as!
I'm currently looking for some rims for my 32 GTR, want them on it before it gets out of the workshop!
https://www.sau.com.au/forums/topic/105631-wanted-pics/#findComment-1945747
yeh phill, im here champ, it looks stock with a thicker frontmount at the moment, in the process of getting n1 front vents, getting rid of the rear wing for the small blade lip and some 19s champ. Used to have r34 gtr 19s.
https://www.sau.com.au/forums/topic/105631-wanted-pics/#findComment-1946527
34 GTR rims? or starcorps??? are you kidding? the 34 GTR rims are a much better rim in many so many ways. not least of which they are forged lightweight, where as the startcorps, are not. only problem is the 34 rims go for around $3K second hand, the starcorps are much less even buying new.
https://www.sau.com.au/forums/topic/105631-wanted-pics/#findComment-1948223
Well said baron
It all depends what you bought the car for really, e.g. if you bought it for track work then buy gtr rims, you wont wond a better track rim for the price
Or if you bought it for cruising and showing off, then buy chromes.
I bought it for a weekend track car and have spare rims for it, but only change them on track days - any other day and the impuls are the go for me
https://www.sau.com.au/forums/topic/105631-wanted-pics/#findComment-1948390
The 34 GTR rims should cost me about $2000 landed, second hand. I could probably bargain the guy down further. Looks like ill go for them, i didn't really know anything about the "technology" behind the wheel. Are 34rims 18s or 19s?
https://www.sau.com.au/forums/topic/105631-wanted-pics/#findComment-1948512
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
