Thought I throw up some pics or mine-will have better pics up soon
R32 GTR was a registered car but used as track/club racer in Osaka
Now Ive re-fitted interior and putting on the road
All the good gear-Trust T517Z's,Custom Greddy inlet piping,Forgies ,Full open CES 4 inch race pipes turbo to tip,Ohlins coil overs,Brembo brakes, OS Gikon gearset in box,carbon bonnet and rear lip etc etc (my wallet has copped a hammering!!)
Looking forward to track day coming up next week then a few test and tunes
Like to drive around streets on 16psi where it makes 301.0AWKW@ 7200 rpm
Making 355AWKW@ 22 psi-set up for circuit with current suspension
Mine is the Black one
The Gun Grey one is a mates
>>.New pics 15/3 showing new Nismo18x9.5 rims on the car
Edited by overev1
https://www.sau.com.au/forums/topic/105797-my-gtr/
thanks-wew are trying to get a GTR cruise going and a meet up at a test and tune-why dont you join us
yeah, sounds good. A mate with a supercharged SS ute has been trying to get me to go to a test'n'tune night anyway. I'm more interested in hillclimbs and sprints, but i do want to see what it'll do on the quarter, just for interest's sake. I'll have a look for that thread
cheers
https://www.sau.com.au/forums/topic/105797-my-gtr/#findComment-1948272
cool, I volunteered this morning to help out in the last volunteer/driver spot, so if they need my services I'll see you out there. I might come out for a look anyway. Would be awesome to see, and hear, it in anger!
https://www.sau.com.au/forums/topic/105797-my-gtr/#findComment-1948333
NICE! 355kw NICER.
Definately now have to organise a GTR cruise for North Bne/Sunshine Coast cruise B) Seems to be more and more nice/modified 32 and 33's around with decent power and street registered!
Keep up the good work and hope to catch up on the cruise!
https://www.sau.com.au/forums/topic/105797-my-gtr/#findComment-1950950
ok i started a gtr cruise topic if your avaliable just add your name and feedback would be good also be good to have a few GTR's gettin onboard for this cruise
http://www.skylinesaustralia.com/forums/in...opic=105998&hl=
Edited by MrVspec
https://www.sau.com.au/forums/topic/105797-my-gtr/#findComment-1953028
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
