YES its on again. I will be placing another order for goods from Japan.
Date of order: 12 July
Date funds are to be IN my account: 11 July
Following are the details. Read carefully.
1.
All you have to do is email me with the item you wish to order. I can get practically anything you want so just ask me. At this stage I will not be ordering large items like exhausts and bodykits as the shipping is yet to be worked out so that I can quote correctly.
2.
Once you have emailed me I will send you a quote. The price I give you is final and not negotiable, I am not in this to make money but I do have to cover all my cost and the fact that if the yen changes I have to bear the difference. The price you receive will include shipping to your door.
3.
If you are happy with the quote and you wish to participate with the buy then just email me with notice that you have deposited the necessary funds into my account. I must have all funds IN my account by the 11th of July, there for you may need to deposit the money a couple of days prior to this date to ensure I get it on time. I also require at this point your shipping address.
4.
Once I receive the funds I will notify you of that and place the order on the 12th July. After that I will keep you informed as to the progress of the order only when I hear from the supplier.
5.
Upon me receiving the goods I will post to you as soon as possible by normal mail.
WHY BUY WITH ME:
The reason why I suggest you be part of this buy is to help reduce the cost of the shipping for your goods. Also, because I have placed many orders I believe that I get better feedback from the various companies that I use.
Please don't reply to this message. I will only respond to private email at [email protected]
https://www.sau.com.au/forums/topic/1059-japan-group-buy-ii/
TOMEI HICAS LOCK KIT SUIT R32 GTST
Hope it's not too late for my order. can have money in your account instantly. Sorry for late notice, please call me on 0411 878 961
Sam
https://www.sau.com.au/forums/topic/1059-japan-group-buy-ii/#findComment-30417
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
