Hi all,
I'm facing a bit of a conundrum.
My 96 GTS-T was stolen last year and I'm looking at getting another one in the next few months. The thing is, I can't decide whether or not to get a GT-R and keep it relatively stock, or buy a modified GTS-T.
Advantages of GT-R are obvious - 4WD, bigger brakes, more power in stock form, better seats, better suspension etc.
Advantages of GTS-T - cheaper (both to buy, maintain, and insure), lighter, IMO looks better (I personally prefer the Series 2 GTS-T bodykit over the GT-R body kit)
What are your thoughts. Is there a compelling reason why I should get a GT-R over a modified (220-250rwkw) GTS-T, which would turn out cheaper anyhow? My old GTS-T was only 170rwkw, and not quick enough!
https://www.sau.com.au/forums/topic/106090-stock-gt-r-vs-modified-gts-t/
  • 6 months later...
nothing beat's Factory R&D and performance IMO ..
a GTR is an upgrade model by Nissan compared to the Gts-t so ask your self why would you want a midrange model when it will not go as hard legaly with out tweaking it to a genoralized sometimes illeagal weaker threshold , will depreciate faster and you will get pumped by other GTR's as far as handling.
I own both. GTR is my daily, GTS25t is my track car. The GTR is naturally stiffer and quicker for a novice to drive. GTS25t is my "challenge" car as I have to be more precise to go fast.
nah actually GTRs are just GTSTs with special bodykits......its like optional leather in Nissan Maximas.bloody show ponies. why get a GTR??
to be honest with u, i would buy which ever you like the most. if you prefer GTS-T, buy it!!! personally i much prefer the look of GTRs, leaving the performance alone.
GTR... If you're buying a skyline you're going to want to upgrade bits and pieces yeah?
The GTR will keep you happier longer. There's only so far you can go with the GTST, and then by the end of it you realise that with all the money spent you could've bought a decent GTR.
I'm speaking from experience. Although, being where I am now, I wouldn't change a thing.
Wow!! Dude, I have that connundrum. I've done all this stuff to my gtst, yet want a GTR. Then I was thinking, if I had a GTR though I would want to run that on the track instead. Then what would my gtst be used for?
Hmmmmm.... Can you expand on your experience? Do you ever want to drive the GTR on the track instead of the GTST? Do you regret doing stuff to the GTST? etc.
No conundrum no regrets. The sprints I used to run in were not for sheep stations, but I liked getting the most out of the GTSt. My plan is to move it on and have a dedicated, unregistered race car but there are no reasons that a GTSt won't be as fast as a GTR on the track. What I constantly see are GTR's with the same mods, the same lack of proper setup and so on and similar lap times to each other, and yet the couple that are well set up are a serious margin faster again. The GTR is simply a better starting point for a novice, but ultimately would be slower around the track due to weight with a decent setup. The GTSt needs stiffening, suspension, responsive power, diff, and when we get this fast possibly greater braking capacity, but it will corner so fast less braking is needed. I'm just not willing to do this to my perfectly registerable GTSt, so will be letting it go for a new race car.
Otherwise it's all personal choice. I like every one of the 5 cars I have, and need good reason to part with any be it RWD, FWD or AWD.
Interesting :D. Thanks for the insight dude.
I recently took my car out onto Oran Park for it's first track outing and found that I was lapping as fast if not faster than some GTR's that were also on the track. I guess my car has been modified alot more than those GTR's that were lapping around the same times though.
Which begs the question, if I had put as much into a GTR as I have put into my GTST would I have a much faster and more fun car to drive on the road and track.
Prior to tracking my car I was regretting that I had spent as much as I had. But since taking her on the track I couldn't be more happy.
if you are contemplating between you have to weigh up the options.. i own a GTS 4 has the same running gear as the gtr just the smaller engine and gearbox.. but sure u could pick one up equally as good as a gtr.. i aint complaining bout mine but a gtr is just a so much better platform in terms of performance..
totally depends what your priorities are. your heart and head will tell you one way or the other (normally in contradiction with each other!).
I came up on the choice myself, for $20k I could get a mint R33 S2, or for $24k I could get a good R32 GTR. The GTR's been a dream car for as long as I can remember but it would be a bit of a waste as a daily, insurance is more, they cost more to look after, and I'd be worried about someone nicking it.
Hence I went the 33. But if I had a garage and a shitter to get to work in the choice would have gone the other way very quickly :D
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
