hi guys where can i find a single turbo manifold to suit a rb26 gt 30/40 flange [t3] prefer steam pipe must be top quality i have looked on the forums but cant find anything promising im in tas bye the way so its hard to find anything for anything if u know what i mean thanks for any help
https://www.sau.com.au/forums/topic/106138-rb26-single-turbo-manifold-where/
WTF? lol
www.calaisturbo.com.au
or if you wanna get technical
http://www.calaisturbo.com.au/
works every day of the week for me :lol:
Stainless doesnt flex "too much".
Another ill informed post i see s13rb26.
WTF?  lol
stainless does flex
go google
or ask any metal fabricator.
yes it flex's.
but it does not
flexi's too much
The main reason for warping of the manifolds, expecially high mounts in stainless is because people dont support the weight of exhaust system, and poor manifold design without re-inforcement
I wonder if google will tell you that :P
:P
stainless does flex
go google
Stainless happens to have a greater rate of thermal expansion then mild steel. Thats part of the reason when you are welding it, if you dont know what you are doing, or dont approach it in a sensible manner it pulls all over the place.
I wouldnt even consider making a manifold out of 4mm pipe. It would weigh way too much. There is no reason why you need 4mm in wall thickness...there is jack all pressure, its purely a heat thing., and the mechanical loads on the manifold when glowing red hot.
So going crazy with wall thickness is a poor way to get a strong rigid manifold. Makes much more sense to gusset the manifolod and support the turbo.. Make sure your front pipe isnt hanging lose, and is supported off the gearbox.
Another problem with going 4mm wall thickness is the difficulty of getting the internal weld bead/penetration on the money. It can be done, but at 4mm you will have to do a root run then another pass etc. Anbd when doing complicate dcollector welds with such a wall thickness its goign to be difficult to get the fit right...so need to make up voids with weld metal, which promotes an inconsistant ID surface which needs cleaning up with a burr etc etc
About 2.4mm is about as heavy a wall as i would consider.
That all said a 4mm thk manifold will probably work great but its a bit overkill...and another thing to consider is that when talking pipe, the thicker the wall thickness the smaller the ID as the OD is fixed. So say 4mm wt pipe will have a smaller internal diameter then 2mm wall thickness...may not be a problem but another thing to consider.
yes it flex's.
but it does not
flexi's too much
:P
If you copy the way the F1 lads did it in the turbo era, with a proper, rose jointed support to take the weight of the turbo off the manifold, and still allow movement from expansion and contraction, it should help
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
