Hi guys,
Probably making a dick of my self here but anyways. I did some searching around and didnt come up with anything about speedo correction, so after sitting around scratching my head i came up with an idea which i thought i would run by you guys.
Basically i want to be able to get an accurate reading from a speedo that is getting its readings from a R34 GTT manual Gearbox which in turn is connected to a s13 auto diff (wheel and tyre size is the R34 GTT standard 17x7.5 and 225/45).
Im guessing that the problem is the speedo cable running from the gearbox to the speedo, i would assume that since the R34 GTT has a diff which has a ratio of 4.111.1 (correct me if i am wrong) that the speedo cable is spinning at that ratio but the actual final drive of the driveline is 3.9.1 so the speedo is reading wrong.
So i thought that if i some how was able to intercept the speedo cable before it reaches the speedo itself and change the ratio of the cable from 4.111 to 3.9 that it would read correctly.
I scratched out these little pictures in paint to illustrate my idea.
Or with the standard s13 tyre size.
Well anyways let me know what you think.
Edited by DORIFUTO_The Future
https://www.sau.com.au/forums/topic/106211-speedo-correction/
I think if you want to fix your speedo, the easiest way is to do it with changing tyres to suit the % difference in ratio's
Find a set of tyres that read 3.9/4.111, so at a 6% error to your standard wheels. As the 3.9 ratio will give more top speed, you need to balance that with faster acclerating tyres (smaller) (i think)
http://www.1010tires.com/TireSizeCalculator.asp
So, using the stock GTT wheels, i deduce you need 225/35R17's to solve your problem.
Could also be in the other direction, i am not sure, i am confused. But thats probably the cheapest/easiest way to fix your issue...
AlexCim - Wouldnt matching tyres only work for a car that hasnt had the final drive ratio changed but which you are sticking bigger rims on?
mr 32 - oh ok cool sounds pretty good, so they will change the speed cables ratio to match what it actually needs to be? I live in Tasmania so yeah unless i get on The Spirit and come up for a trip then i dont reckon sydney would be viable :D anyways thanks for that ill have a hunt around down here and see if i can find one.
Well, the way i see it, you are chaning the ratio of the engine to the rear driveshafts (like, the half shafts)...sooo... to compensate for the change in ratio of the spinning of the axle, you change the ratio of the axle to the rolling diameter to compensate..
Lots of annoying maths, but i think i had it right.
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
