Anyone jsut wondered if anyone is going? I would but have to stocktake at work, spewing!! To people that havent been you should go, its massive, One guy stocks all import parts which is good, good prices to, was going to buy a full set of Enkei rims for like $1300 but were off a 32 GTR so wrong offset. So ending up buying a set of stockies with ok tyres for $100!!
Last year on the road opposite the airport was a white R33 GTR, looked hot. A Stagea in the parking lot along with heaps of other imports, and inside were a few imports, the hottest looking 32 4 door Ive seen, for sale, mmmm.
Anyway, sucks I cant go just wanting to make sure you guys know its on!!!
Cheers.
Daz.
https://www.sau.com.au/forums/topic/106665-ballarat-swap-meet-this-wkd/
Last time i went the the swap meet i was like 11 years old with my dad. And it was fairly boring. Might have to check it out again some time. Its normally a fairly big day with lots of walking.
KamikazeR33 Im from Warrnambool, down on the coast, Ballarat is only around 2 hours from me. Yes its a huge place to walk around but well worth it, Ive lost count how many times Ive gone, but still remember looking for different parts. It was really wierd going and looking for Skyline/Import stuff the first time! Plenty of bogans go though!
warnambool ay...ill have to keep an eye out for your beast next time i visit my cousins :D
Hey Dezz yeh for sure, not many lines down here though. There is a mint RX7 late model, all black with black Rays, man it looks tough!!
My car is easy to spot, all black 33 with custom plates!
sounds good mate, i gotta try get up there to see em on a weekend soon....maybe after i get back from qld which is march 19th.
PM me if you've got MSN and ill add ya...i got a black 33 as well :(
I do know him Russell, its a GTS-4, turbo etc, GTR front, very nice car, its for sale for last I heard around 17g, full respray etc. I agree very tough looking 32. You members should have a cruise down here sometime!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
