  • Replies 50
G'day, I have a my 98' Stagea since Nov. last year, havn't seen any others about and was keen 2 find out if there where any others in Tassie. Cheers.
Hey Jason
there are 4 or 5 getting around down south (2 are 4 SALE)
silver, red, yellow and black :O
AWESOME car and i wish i had one as my daily :D
post some pics up of your ride mate
Cheers GMB
https://www.sau.com.au/forums/topic/106752-stagea/#findComment-1970204
post-14079-1140672931.jpgThere's mine below. It's 1997, fairly factory standard. No money/time to do anything yet.
The list as far as I know is a dark green one that was bought around the same time from Dave Powell's. It's a 1998 and belongs to an older guy who lives just around the corner from me. I've had a chat once, and he's pretty chuffed with his except for the mileage. He managed to get a manual from somewhere in NZ.
There is a silver one up Burnie/Smithton way which is more customised. That owner is a member here, but I can't remember his handle. This might be the one seen in Launnie. There is also a bright yellow one that I have only seen once at a distance.
Mine has a stagea sticker across the front windscreen so people know it's not a volvo. Even when stopped by the police, they gave up and just wrote nissan wagon. It's also for sale if you want it.
That is all I know.
https://www.sau.com.au/forums/topic/106752-stagea/#findComment-1975211
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
