If there is enough interest we should be able to fit in a drift session.
I think from memory I got 5 track days and about 10,000 k's out of my compliance tyres (read cheap and nasty) so yes there will be some major wear but as long as they are not almost gone already you will still get many more k's out of them.
  • Replies 389
Posted Images
Please ignor my ilitericy (ha ha), I re-read the post to see SAU & RENEWS, not UAS & RENEWS. I will book in once the minister of entertainment and finance passes my application.
What about spectators can they just turn up, is there a entry fee???? or is it a closed event as we are new and moving to sydney and I would like to check out ORAN PARK as we have only seen it on tv and some of the drivers :)
I live about 5 mins away from Oran, I'll be there for sure. I've been going out there at every opportunity since I heard the track is due to be closed.
If you need a flag marshall, i'm more than happy to give it a go - i'll need some pointers as to what needs to be done.
Cheers,
Matt
No entry fee for spectators and you could even volunteer to be a flaggie like Matt.
Matt we would very much like you to be a flaggie as we need a few.
Thanks for volunteering, I am booking you in for it.
Abo Bob,
Yesterday at the Aaron McGill Drive day my wife did not get a chance to drive my car and said she would like to get out and have a go. Whats the best way to go about this. I understand she will need her L2S, but she would like to have me in the car when she goes round the track, will this be a possibility on the day. Whats the cost for 2 drivers and 1 car? The wife does not like Oran Park that much so she is probably only going to do 1 or 2 sessions.
Let me know in a post or call me to discuss.
Thanks
Let me In.... :laugh:
I was out on Sunday at OC GP in the new 15 year old datsun & want my final go in the 72 (REAL!!!) skyline, more fun beter noise.
She is going up for sale for real this time, I can't/won't fit a baby seat in it and the boss said I'm only allowed some cars....
hahaha. that's a good one. havent laughed this hard in a while.
ps. I am also interested to know what the situation is with one car, two drivers?
Well make sure you pay up on pay day so you don't run out of money.
This will be a worthwhile day for you to get a good feel for your car.
There will be plenty of people around to instruct on the day.
About time fatzzzzzz. Let's see how that thing grips!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
