  • Replies 389
Posted Images
You have to be an absolute tool to bump someone and vice versa. The day is pretty much everyone at their own pace and the fast cars seperated from the slower ones. People are pretty much told to move over for faster cars. All the track days I've been to I've never seen an incedent where cars collide, only close ones.
Bonkers, I've been sending you emails all along about extinguishers and the like.
I don't think that's ok yogi. The easiest way I think is to get a strip of aluminium from the hardware store, two holes, one at either end then bolt it to the same holes that your front seat mounts are using. So under your legs.
Then the bracket of the extinguisher bolts to that strip.
I've never seen an accident either. Also we kick the idiots off the track so as not to endanger you.
the only extinguisher in the small size worth buying is made by BFI. it's 1kg empty, 2 kg full. all extinguishers to be used in a cams event need to be metal, at least 1kg and mounted with a metal bracket. the usual torpedo shape ones people use have a fire rating of 5, the BFI ones rating is 20 so it will put out 4 times as much fire. i've shot off a few types and some of them are pathetic, the BFI one is good shit. so my advice is pay a little more and get one that will really save you or your car if needed.
my extinguisher is in the passenger side, near the end of the foot area on the door side, if that makes sense!!
fitted it in a few mins, bought it auto 1 a while ago
i wont be racing, however ill try and make it down, if i do ill volunteer to be a flag marshall, however i wont know till a few days before
cheers,
chris
I just had a set of 2nd hand GT3 porche cup slicks fitted to my spare set of GTR rims, although they are suppose to be 240's they only just fit on the 9' rims. Lets see if they last a little longer then the last set of yoka's I had!
Cheater! Double cheater!
eek.. the one I have is mounted with a strong, quick release style plastic bracket.. It's definitely not going anywhere in a hurry, but is easily removed. Is this going to be ok or is it STRICTLY a metal bracket?
The plastic bracket ones should be OK but next time (!) get a metal bracket it is a problem with some scruitineers.
For those worried about making a hole in the carpet, feel free to check out the Zed's passenger floor....you will never spot where the extinguisher used to be :whistling:
i think we may have gone a little OT here. i havent seen the regs for this event (or even if it has any) so i dont think any extinguisher is required. is it? BUT to answer the question, in nsw super sprint series run under CAMS approval the bracket must be metal, and the extinguisher mounted within reach of the driver. it must also be a minimum 1kg dry powder type. the plastic ones will not pass. neither will ones out of date. neither will the ones under 1kg. but like i said i dont think any is required for this?
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
