wilch...the easiest way is to pull the bolt out that holds the back seat down on the passenger side...then put the extinguisher bracket there and put the bolt back through it.
that or just drill through the passenger floor, the holes are tiny you would never see them.
the bracket method needs a piece of metal as wide as the seat mounting bolts...take the seat bolts out and put the bracket under them, then seat bolts back in. Rivet the extinguisher bracket to the metal
  • Replies 389
Posted Images
BWA you need $85 for the licence and $29 for the extinguisher.
Yes we do need them Mr Baron and there is no requirement for metal brackets.
thanks for clearing that up. :angry: sorry for the mislead.
That makes things a bit easier, but for those wishing to use their extinguisher at other cams event my advice would be to go straight for the metal bracket one as all events i've entered require it.
i just got out the extinguisher to take a few pics that may help:
front with extinguisher mounted:
back of bracket (mine is bolted to the bracket)
better view of bracket without extinguisher:
fire rating (the 20 is the cruicial part, the bigger this number the better)
I made my bracket out of aluminium then machined it a little to give it that 'brushed aluminium' look and take off the sharp edges. one of the holes is elongated to make it easier to bolt down. because the floor is not flat it has a slight bow in it when done up tight.
So Wilch, I just realised that you seem to be expecting me to bring an extinguisher with me. I never got a reply from BWA to confirm this.
Can you please confirm your understanding of this? you could email me on bob at estc dot net dot au to make my life easier.
Not saying that's not a good method at all but thought I'd throw in an alternative.
I got a piece of metal (read: strong) and bent it at a 90 degree angle kind of an "L" shape. Long ways I've mounted the fire extinguisher on and the shorter side I've rivetted into the back of the console box in the rear. Basically where the drivetrain tunnel is between the 2 passenger footwells. Works great and keeps it out of the way of passengers in daily traffic mode.
I'd also like to say STAY AWAY FROM CHEAP ASSED FIRE EXTINGUISHERS.. Please. I bought a Chubb because I trust the name. I bought a 2 pack of fire extinguishers before this one only when I needed it BOTH FAILED (bought from a cheapo repco type store for $30 for the pair)... Beware!!
I've used 2 cable ties and put two grooves in the bracket to put them in. Works awesomely.
Is there anything they can't do?
That's probably the only situation I'd not use zip ties in just incase in impact they're gonna let go. Certain angles they love to snap (hence why they're suited to holding on my front bar haha)... Then again I spose you've probably thoguht of this already and got a few on there holding them from different angles :)
Question on passengers. Yes or No? If there's a drift session would love to take my gf.
agreed, like i said, i've used a few and some are very lame. the BFI one i posted above is the only one i buy now for use in my car. seen one of them in use before and it's awesome. minimum dischage time is 13secs too.
having said all that, i would be very surprised if any of you guys ever need one. it doesnt happen very often.
doodz, where do you live?
Marourba :)
Foud out how to get there now so it should be ok.
Just gotta figure out what time people will be there..
From the City of Sydney
Take the Eastern Distributor past Sydney Airport to the M5 motorway. Follow the M5 to the Camden Valley Way exit.
Follow Camden Valley way to Cobbitty Road, turn right into Cobbitty Road and the Cobbitty Road entrance is less than 5 minutes away.
From the Western Suburbs
Take the M4 to the Northern Road exit and follow Northern Road to Oran Park Raceway. Oran Park Raceway is about 25 minutes from the Northern Road exit of the M4.
From North of Sydney
Exit the Northern Freeway at Hornsby and follow the pacific Highway into the city, Take the Sydney Harbour Tunnel and follow the directions from the City of Sydney.
From South of Sydney
The easiest way is to find the M5 and take the M5 to the Camden Valley Way Exit as described above.
I just got the email from Nathan from RENEW.. I was wondering about the CAMS licences... Are we supposed to sort these out directly with cams to get the licence, or are we able to do this on the day or something? I've already submitted these forms to Abo Bob. Are you submitting these for us, or should we bring copies on the day?
I have a mental checklist of stuff to bring, please let me know if I'm missing something:
- Helmet
- CAMS Licence Application Form
- RENEW/Oran Park Track Day Entry Form
- Mounted Fire Extinguisher
- Tools/Oil/Maintenance stuff
- Long clothing/Leather shoes
- Car!
Also is anyone comming from out west.. like penrith or mt druitt?
So i can follow them?
OK easy run down on how to get to Oran Park.
People North of the bridge, simply head city way and go tunnel & Eastern Distributer.
People other side of bridge you simply follow the ED out towards the airport and continue to follow it until u reach a tunnel that literally goes under a runway.
Be in the left hand lanes thru this tunnel as once u get out the other side the road will split into 2.
One will go off to the Right signed for Canberra, you NEED to take the LEFT exit heading for Liverpool.
Now just follow this road for ages. It will turn into a freeway just after the King Georges Rd exit.
Follow the freeway for a good few km's. Now once u hit to toll booth's, it is the 4th exit on the left (Camden Valley Way EXIT), but it is actually called BEECH RD exit (same thing).
Take this and chuck a left @ the lights then u get to an intersection about 200m's up the road called "The Crossroads'.
Turn RIGHT at these lights and this is Camden Valley Way. Follow it for a long long time...maybe 20 mins. Once you get to the other side of a suburb called Catherine Fields its not far. Cobbity Road is on your right.
Pretty Easy really! :D
So what time are people turning up??
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
