I've had the SDU PDF book for quite a while and it has been a useful reference up and as far as it's more a "32" reference than a 33 or 34 tome.
Do we have the capability to come up with a Australian based guide to the Skyline?
Here's the SDU book for reference:
http://www.nitroware.net/~tony/skyline_book.pdf
T.
https://www.sau.com.au/forums/topic/10693-do-we-need-a-skyline-owners-book/
Go get 'em boys & girls.... the wait is over
http://www.jpnz.co.nz/manuals.html
BTW, I have a full set of papers and I mean FULL. Things like owners manual (R33), dealer warranty card, RWC, rego papers, Rego label (unpeeled), Puretron manual, service book with all coupons, about 30 or 40 receipts for everything but fuel, stickers (unpeeled), etc, etc all in the original plastic gatefold complete with the Dealers business card & photo ! the dealership was Nissan Prince in ***uoka (Kyushu).
I'm led to believe that it's ultra-rare to get all papers with Jap imports - True or False ?
Is there anyone in these forums who can translate written nihongo ??? I can scan and email any of this for anyone who can assist.
I would be more than happy to share this treasure trove with all who are intersted if we can get it translated....
LOL fu-ku.....
I got the owners manual, service manaul, service history and a few other things with mine.
Most the stuff is in japanesse and probably says something like "this car is crap and is going to blow up soon. I'm going to sell it to some stupid Australian bloke"
:bonk: :bonk:
i got most of the documentation too... since mine was jus an average family car (in some way or other) I got the registration and derego paperwork and full service manuals, and even manuals for the aftermarket exhaust and other mods that were done to it. Oh and a membership card to some Nippon holiday cruise club or sumfin... and also the stickers n stuff including the Japanese Automotive Federation or sumfin, which I think is like the NRMA over there... oh and my flare!!!
  • 2 months later...
Jamezilla: how much did it set you back [if you dont mind me asking]? How many pages in it?
I know they are advertised at around $50 but isnt that in NZ dollars? Then of course freight would also need to be added for shipping to here...?
Cheers!
JPNZ has two manuals available. The Owners manual (which I have purchased) is your basic manual which would come with any new car - basic operation car, radio, lights, brakes, bits and pieces, location of jack blah blah blah. The other manual available is the Engine Service manual (500+ pages and just about enough info to remove and install an engine.
BE WARNED - I have looked extensively into the legal side of this and any copying of any manual and distribution of it (even if it is a JPNZ manual from New Zealand) is completely ILLEGAL. The fines if caught with or distributing an illegal copy are just not worth it. I think that NZD$250 or AUD$225 for an engine manual as rare as the R33 is a bargain.
This has been discussed before on the SDU/SAU forums and a thread has been closed by a moderator due to continued discussion of copying of manuals.
  • 10 months later...
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
