i have tried searching but couldnt find too much on this.
i was thinking of putting an r34 gtt power fc into my stagea (series 2 rs four s manual) will this work, and how will it affect things like climate control and AWD etc?
https://www.sau.com.au/forums/topic/107425-power-fc-in-a-stagea/
  • Replies 52
I've also done a search, and found nothing relevant on hardwiring the ATESSA system.
Does anyone know what's involved, and is it a simple or a major process?
I'm really keen to do this, as I'd like to find that balance between better fuel economy, more power, more responce, etc., and PowerFC is amongst the best solutions (closed loop and plug-and-play are major factors).
Its a simple process. Think along the lines of, stagea ecu has seperate outputs on the harness for the attessa requriments, where the GTST doesnt. Therefore, its just 2 wires coming out from the single pin.
Read from about post 8.
By the way, goldzilla....you even replied in that thread :D
http://www.skylinesaustralia.com/forums/in...c=92908&hl=GTS4
Mercury Motorsport said that the PFC they used didnt need the engine harness to be cut/modified at all, BUT, a guy from Japan that did Goldzillas car said the GTT plug doesnt fit, ALSO, the R34 GTT neo engine has infinatly variable VVT where the R33 engine has it only on/off. SO, not sure what MM did about that, but they wouldnt share...its a secret
By the way, goldzilla....you even replied in that thread :yes:
Yeah I did too, Alex! But that thread is so old I'd forgotten all about it and don't remember checking it for replies.
Hmm, the saving continues... Concentrating on the stereo for now (at least getting some replacement speakers, anyway). I can handle (and am quite enjoying) the power the car already has, and would like to get suspension and wheels first, once the stereo is at least partially sorted...
EDIT: Alex, did you end up taking your car to the PFC distributor to see what works/doesn't work before making your PFC purchase?
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
