What is PSI??
The other guys have most of it right.
Yes it does mean pounds per square inch, this was the old imperial measurement for pressure. Bar has been since we moved over to metric. Americans still use imperial mesurements on somethings, and so psi is still commonly used.
Pressure is a measure of force over area.
Most engines will run at a vacuum while idling, an NA engine will go to 0psi at full throttle, a turbo engine will create a positive pressure over and above atmospheric pressure.
See'ya:burnout:
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-174371
Actually I think atmospheric pressure is 1 bar or about 14psi?
That is the amount of all air above us pressing down on all objects on earth (air has mass and weight as any other materials). This is accepted as the standard pressure. We don't feel the air pressing against our skin or eyes coz our body is designed to adapt to it thru our evolution. Otherwise we'll all b crushed to death by now.
So actually NA engine actually runs the same pressure as the atmosphere at full throttle. Turbo engine runs more than the atmospheric level, depending on boost controller.
However to make things easier, the atmospheric pressure is set as 0 psi on boost gauges. So if your factory boost gauges shows 7 psi, that means the air pressure going into the engine is the 7 psi above atmospheric pressure... you are running positive pressure....
Sounds confusing, I read that thing from howstuffworks.com, however to avoid further confusion, let's accept that NA engine runs 0 psi (on boost gauge) on full throtle, and factory R33 boost is around +6-7 psi on the boost gauge.
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-175294
psi, psia, psid, psig
traditional symbols for pressure units used in hydraulics and plumbing. psi is a symbol for pound per square inch (see above). psig is a symbol for pound per square inch gauge; this means that the pressure has been read from a gauge which actually measures the difference between the pressure of the fluid and the pressure of the atmosphere. psia means pound per square inch absolute, which is the total pressure including the pressure of the atmosphere. psid, pound per square inch differential, is a symbol for a difference between two pressures, neither of which is atmospheric pressure. Corresponding symbols for pound per square foot (psf, etc.) are also used.
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-175315
OH and while I am at it
PS = pferdestärke
German word for horsepower, meaning the metric horsepower. The symbol ps is used for horsepower in both the Japanese and German automotive industies.
HP = Horse power (Metric Horse power)
a unit of power, defined to be the power required to raise a mass of 75 kilograms at a velocity of 1 meter per second. This is approximately 735.499 watts or 0.986 32 horsepower. The unit is also known by its French name cheval vapeur or its German name pferdestärke.
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-175319
The japanese like to use PS as their measurement for horsepower! Conversion is 1 horsepower = 1.01387 PS
Brake horsepower (bhp), sometimes called shaft horsepower, is the amount of power available for useful work. Bhp is less than flywheel hp because of the various power losses which occur during engine operation.
To determine the brake or shaft horsepower that is delivered as useful work by an engine, the sum total of all mechanical losses must be deducted from the total HP (initial or flywheel horsepower). BHP is the reading that dyno's use! This is also sometimes called RWHP or Rear Wheel Horsepower!
Here is an online conveter so if you know your HP and want to find out the PS/KW
http://locost7.info/converter.php
MEGA
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-177053
rs73,
Your right that atmo is about 1 bar, that's why I said that turbo engines read over and above atmospheric, while NA reads 0psi relative to atmo.
So we are in fact using psig, relative to gauge pressure, that is we take all measurement relative to 1atm.
See'ya:burnout:
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-177065
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
