What is PSI??
The other guys have most of it right.
Yes it does mean pounds per square inch, this was the old imperial measurement for pressure. Bar has been since we moved over to metric. Americans still use imperial mesurements on somethings, and so psi is still commonly used.
Pressure is a measure of force over area.
Most engines will run at a vacuum while idling, an NA engine will go to 0psi at full throttle, a turbo engine will create a positive pressure over and above atmospheric pressure.
See'ya:burnout:
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-174371
Actually I think atmospheric pressure is 1 bar or about 14psi?
That is the amount of all air above us pressing down on all objects on earth (air has mass and weight as any other materials). This is accepted as the standard pressure. We don't feel the air pressing against our skin or eyes coz our body is designed to adapt to it thru our evolution. Otherwise we'll all b crushed to death by now.
So actually NA engine actually runs the same pressure as the atmosphere at full throttle. Turbo engine runs more than the atmospheric level, depending on boost controller.
However to make things easier, the atmospheric pressure is set as 0 psi on boost gauges. So if your factory boost gauges shows 7 psi, that means the air pressure going into the engine is the 7 psi above atmospheric pressure... you are running positive pressure....
Sounds confusing, I read that thing from howstuffworks.com, however to avoid further confusion, let's accept that NA engine runs 0 psi (on boost gauge) on full throtle, and factory R33 boost is around +6-7 psi on the boost gauge.
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-175294
psi, psia, psid, psig
traditional symbols for pressure units used in hydraulics and plumbing. psi is a symbol for pound per square inch (see above). psig is a symbol for pound per square inch gauge; this means that the pressure has been read from a gauge which actually measures the difference between the pressure of the fluid and the pressure of the atmosphere. psia means pound per square inch absolute, which is the total pressure including the pressure of the atmosphere. psid, pound per square inch differential, is a symbol for a difference between two pressures, neither of which is atmospheric pressure. Corresponding symbols for pound per square foot (psf, etc.) are also used.
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-175315
OH and while I am at it
PS = pferdestärke
German word for horsepower, meaning the metric horsepower. The symbol ps is used for horsepower in both the Japanese and German automotive industies.
HP = Horse power (Metric Horse power)
a unit of power, defined to be the power required to raise a mass of 75 kilograms at a velocity of 1 meter per second. This is approximately 735.499 watts or 0.986 32 horsepower. The unit is also known by its French name cheval vapeur or its German name pferdestärke.
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-175319
The japanese like to use PS as their measurement for horsepower! Conversion is 1 horsepower = 1.01387 PS
Brake horsepower (bhp), sometimes called shaft horsepower, is the amount of power available for useful work. Bhp is less than flywheel hp because of the various power losses which occur during engine operation.
To determine the brake or shaft horsepower that is delivered as useful work by an engine, the sum total of all mechanical losses must be deducted from the total HP (initial or flywheel horsepower). BHP is the reading that dyno's use! This is also sometimes called RWHP or Rear Wheel Horsepower!
Here is an online conveter so if you know your HP and want to find out the PS/KW
http://locost7.info/converter.php
MEGA
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-177053
rs73,
Your right that atmo is about 1 bar, that's why I said that turbo engines read over and above atmospheric, while NA reads 0psi relative to atmo.
So we are in fact using psig, relative to gauge pressure, that is we take all measurement relative to 1atm.
See'ya:burnout:
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-177065
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
