  • Replies 57
just got swaybars on, and new front tyres. Need neg camber on the front, and brakes to go on, and then its all systems go.
Having major trouble finding front struts (the bit the calliper bolts to, and the shock sits in) with 4" calliper mount spacing (same as yours scott)... this is the only real holdup!
I organised today to take it to a bloke to get them custom mounted. If you can get them ill just go down that road, but if not ive got a backup plan. Import or aussie GTS, as long as they have the 4" spacing between the centre of each calliper mount hole. Its the part that the shock sits in, and calliper bolts to.
good luck :(
Guest SVD001
13 days to go till sprints...... I'll see what I can do Slip.. Might be quicker for you to get the brakes mounts fabricated. Will let you know. If only my 180b had some grunt I'd race that. Just installed F&R swaybars I had lying around. Lowered it and Got my hands on some full on rally rear koni's.. Can't wait to drive it...Go the Little Groover...
Ok. The QR Raceway site now has more details than last time I looked, so check there for how this all works and latest pricing.
http://www.queensland-raceway.org.au/
Hope to see a few of you out there. Also was thinking of cruising out from Bris as a group, so let me know if you want to meet (like in the city) first and then head out. I wnt to be there by 11am to make sure we get places.
Hope to see u there ;)
OK, so now its getting close. Does anyone want to cruise out together or is everyone making their own way? We could work this out at the tyre night tomorrow night since I think a lot of us will be there.
So see you tomorrow, or saturday, or around.
Cheers
