  • Replies 57
just got swaybars on, and new front tyres. Need neg camber on the front, and brakes to go on, and then its all systems go.
Having major trouble finding front struts (the bit the calliper bolts to, and the shock sits in) with 4" calliper mount spacing (same as yours scott)... this is the only real holdup!
I organised today to take it to a bloke to get them custom mounted. If you can get them ill just go down that road, but if not ive got a backup plan. Import or aussie GTS, as long as they have the 4" spacing between the centre of each calliper mount hole. Its the part that the shock sits in, and calliper bolts to.
good luck :(
Guest SVD001
13 days to go till sprints...... I'll see what I can do Slip.. Might be quicker for you to get the brakes mounts fabricated. Will let you know. If only my 180b had some grunt I'd race that. Just installed F&R swaybars I had lying around. Lowered it and Got my hands on some full on rally rear koni's.. Can't wait to drive it...Go the Little Groover...
Ok. The QR Raceway site now has more details than last time I looked, so check there for how this all works and latest pricing.
http://www.queensland-raceway.org.au/
Hope to see a few of you out there. Also was thinking of cruising out from Bris as a group, so let me know if you want to meet (like in the city) first and then head out. I wnt to be there by 11am to make sure we get places.
Hope to see u there ;)
OK, so now its getting close. Does anyone want to cruise out together or is everyone making their own way? We could work this out at the tyre night tomorrow night since I think a lot of us will be there.
So see you tomorrow, or saturday, or around.
Cheers
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
