ewww.. vespas are not sporty or fast!!!! :O
sif alien knows anything!
But he told me you two used to be a hot ticket item
(Then again, i get the impression hes never touched a female before)
So whaddaya say Mona, good times? I promise I wont take photos, or if I do you can have a cut of the proceeds once i load them on my website
Edited by R33
  • Replies 268
Popular Days
yeah... but it means i'm a nagging annoying female and norhing more, ms!
quote dammit!! i had to go back to the other page and re-read what i wrote to find out what u were on about ....
are u sure there is nothing else?
sif quote!!
nothing else!
and i think r33 is someone we know using their old account!
hahaha... richard.. who cares if the movie sux! as long as the guys are hot! :O
Typical women, only watching movies to perv on the men.
We arent chunks of meat you know Moanie, we have feelings
yeah he's a dream boat...
Sugoi
sif quote!!
nothing else!
sifnt quote and i reckon there is..........
i was just about to say that.... currys only watch movies that have their favourite actor/actress in the movie.. they dont care about the story.. ;o
:O i actually find it amusing hanging around with guys all the time... a hot chick walks past... and convo stops... jaws drop... lol!! priceless!!!
hahaha.. i do!! :tongue:
see!! i quoted :ohmy:
Garbage, name one guy here that would eye off a hot girl that happened to walk past.
damn i just wasted 20c sms ing you thomas. word is i just enrolled in japanese class at Syd Uni. paid my money and everything.
hahaha why is it a waste ??/
you bastard....I thought you enrolled before me !!! and was waiting on me !!
I was broke that week and I scrapped the cash together so I wouldnt miss out !! :tongue:
Anyways when do you wanna get our books then ???
Im going in tommorrow to buy some Hyper Rev mags amongst other things....might see if I can find the books we need.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
