Hi Guys. I'm interested in starting a group buy because I want to see if I can get these water Methanol Kits any cheaper from our Australian Distributer. I guess the more the merrier.
Heres the good bits. (Taken from Snow Performance in the states)
ZeroDefects:
Sorry for the late post, I had lost track of this thread.
When tuning your engine for an A/F of 12.5 and using the the Boost
Cooler compared to a "Tuner Safe" an A/F of 11.5, you are replacing
10% of the fuel with the W/M. In boosted engines the amount of W/M
injected as a percentage of fuel is higher.
As a rule of thumb, the W/M will increase the octane rating of the
fuel by 25% irrespective of the grade of fuel.
So 87 pump gas you would be at 108
90 pump would be 112
93 pump would be 116
There would be little to no increase in octane from the W/M if race
gas like C16 was used due to the already high octane number of 116.
Best regards,
Dan
I would also like to add that a friend of mine has a 375rwkw kw Toyota Supra Running this exact same kit, and its awesome. We have shit fuel in mackay - 95ron is the best we can do, and all he could get was around 310rwkw on his setup (fmic, GT40 turbo, exhaust, 22psi boost, injectors and haltek).
Once the kit was fitted, it eliminated all signs of detonation, and he wound the boost to 28psi, and heaps more timing, and then 375 rwkw. All on the standard supra bottom end (they are forged from the factory)
He measured 100hp (60rwkw) gains, and I am assuming that if you run the right setup and tune you car properly, you would manage a good power gain. I don't think you'd see as high as him though unless you are running high boost.
There are other benifits
**cleaning your entire intake manifold, pistons, etc etc
**lower intake temps which is always a good thing.
** Ron Rating through the roof - Like running constant Av gas
** Costs about $6 a tank extra (cheaper, and about 10 times better than a bottle of octane booster) Distilled water is about $1 a litre at Supercheap, and Methanol is about $1 a litre. 3 litres does about 1 tank of fuel.
** Has optional safe guards if you run out of water meth)
Now I am not a pro, so I suggest you do some research on this, but its definately a good option.
More points -
** Water meth is only injected on boost
** There is a variable controller - which means you dial in a start boost, and a finish boost. This means you don't have one constant pressure (causing the car to surge when it comes in) it means you start off with light water and the pressure increases as the boost and load increases. Perfect.
** There is a saftey system (optional extra worth the $$) When the water run out, or the pressure drops from a blockage, the saftey systems opens up a solenoid that reduces your boost to whatever your wastegate i sset to (mine is 7psi, I run 16 psi max)
I have no idea on price but will update you guys when I get it in the next few days.
Hope people are interested!
here are the sites to look at if you are interested
http://snowperformance.net/products.asp?id=1 (there is also a forum)
http://www.full-throttle.com.au/Engine/Boost Cooler.htm (where I will be getting them from)
These are the options I will be getting -
*Boost Cooler Stage 2 Kit With the Variable Controller (comes with a 220psi pump)
*Solinoid Upgrade - Stops gravity Feeding
*6 Litre Reservior
8Fluid Level Switch Upgrade - Indicates fluid level.
*Safe Injection™- boost/timing reduction system for use with the Boost Cooler® water/methanol injection system promises to revolutionize the industry by providing for safety even with the most aggressive tunes.
*Wastegate Solenoid Upgrade - Solenoid such that boost is reduced in a wastegated turbo set-up.
Watch this thread for pricing (will be around the $1300 mark) and open times and close times)
Thanks guys
I've done a group buy before and I'm fairly well known here. I will not rip you off...
anyway. Let me know your interest!
Edited by The Mafia
yes it does, but you don't have to fill the water meth tank up exactly at the servo..
Just fill it up every weekend or something like that. As long as the tank has fluid in it the system will work fine. If it runs dry, stay off boost.
Also, bare in mind that its only misting water in during boost, so if you stay off boost, you aren't using it..
Also, these systems don';t do anything if you don't tune your car to them. If you have your car tuned with a shitload more timing and different afr's and you de-activate the system, you're motor will go "snap crackle pop" and then go bang.
its more of a permanent fuel improvement solution.
I'm going to whack one in, tune it to 91ron fuel (which would bring the quality of fuel to about 110 fuel) which would be like running avgas all day every day for $1.00 a litre (or whatever 91ron is these days) plus $6 a tank for the water and meth.
Apparently normal tap water can even be run through it without a problem. I might ever try it. If you use clean tap water (or even rain water) you'd save $3 a tank, meaning it would onl cost you $3 a tank extra to run avgas quality fuel in your intake.
I know its a high setup cost, but once its in....power...stability...engine longevity..etc etc..
Edited by The Mafia
This sounds interesting indeed... I run 98 RON fuel, this would jack it up to 110RON +
Question is; has this system been tested thoroughly by your mate? Interested to know what the full setup looks like, what components are included, and ultimately the cost involved.
pretty intersted mafia,
just a question, do you put the water and meth straight into ur fuel tank?
would like to see some photos of the setup, install in a car, and also like to know is it something i would be able to pull off or would i need to take it to a workshop to install
My mate says its one of the best kits he's seen, and he commented quite a bit on the jet saying its very good at misting the water (the finer the mist the better) and its much better than some of the other jets he's used.
My mate has been running for over 6 months now, has been able to run 7psi extra boost, and about 7 degrees more timing on full boost (thats a lot of timing) and the car went from 310rwkw to 375rwkw. He did a compression test and the result were the same after 6 months.
Definately been tested thoroughly.
' date='2 Mar 2006, 03:31 PM' post='1990752']
No, the water meth kit has its own reservior. You mix the water and methanol together (50\50) and stick it in the reservior. Then the varible controller has one of your boost lines attached to it - It starts injecting water in at the boost you set it to start at, and then increases the pressure in a scalar fashion to your maximum boost setting (to prevent choking). There is a 220psi pump involved, and a few little things inline to the jet.
The Solinoid stops the water meth syphoning when the manifold is on vacuum, and the reverse check valve stops the boost blowing the water back up to the pump.
You fit the jet 500mm from the throttle body (to give it a good distance to mix and mist) and then done.
I'm pretty sure you could fit most if not all of the kit yourself. It comes with full instructions and everything you need to fit it.
This only thing you'll need to pay for after the kit install is the tuning. (I'm going to tune it myself, I seem to know what I'm doing...lol I hope)
I could be interested in one too.
These kits are universal? Or model specific ones need to be made up?
When u say the jet should be positioned 500mm form the throttle body, i assume thats on the pipe connecting to the throttle body? (somehow i think that was a dumb question, but had to ask it anyway >_< )
i purchased a kit from cooling-performance a month or 2 ago.. It was about $400.. i found most were about $350-400.
I havnt put it on my car yet as my cars getting some other work done first, but i'll slap it on in the next few weeks and post up the results.
yrs ago i was running a turbo holden 6 at speedway we made our own meth injection system all we used was a washer bottle and motor with a small one way check valve connected up to a hobbs adjusable preasure switch and just plumbed it in b4 the throttle body .we did nor tun any more boost we used it to controll knock and it fixed that prob no worries some of you smarter guys could make ya own systems really cheap prob under 80 bucks if ya sit down and think about what ya actually get for ya money in a 400 buck kit
cheers midlife crisis
yeah thats true, i kinda regret spending $400 now. With me though id prefer to buy a tested solution then to sorta stuff around with it myself. Just cause theres potential to screw something up bigtime.
The actual mechanical components are very cheap and easy to buy/make. The problem with water injection as always is the engine safety aspect. What happens if I run out of water? What stops the engine filling up with water, hydraulic lock is not a pretty thing? What stops me injecting too much water and it getting into the oil? What happens if the pump fails because it is not designed for methanol? etc etc
That’s where the value of a complete kit comes in. They have the one way valves and solenoids to stop hydraulic lock. They have warning for low water levels. The have the sophistication and programming in the control circuit so you can adjust the water flow using the AFM signal or the MAP sensor signal. The pumps have sufficient power to mist the spray against the boost pressure (150/220 psi is heaps of pressure) and internals designed so as not to corrode when in contact with methanol.
:D cheers :laugh:
:D cheers :laugh:
well back then you could not buy one of the shelf the one way check valve stopped any hyd lock probs we had a light connected to a float to warn of low meth water we only used to fill it once during the night at the start of the meeting dummm speedway holden 6 to to many electronics to worry about all im saying is this is not a new idea i was doing 20 yrs ago now there are complete kits well thats great news for non thinkersbut the same princapals apply today as then and if i was going to use one i would still have a go first never had a washer pump fail and the nozzles we used to tap into the plenum was actuall ma gee or endleee machanical meth nozzles this wasent some half baked things we used we actually sat down done the sums and gave it a go .and i can say the 4 or 5 seasons we used the system it worked great for us
the most expensive part of the kit is the pump. a good 100psi shurflo pump will set you back a few hundred dollars easy.
all the other stuff is realatively easy and cheap to obtain.
one thing that people have to remember is not to just buy any old kit, you need to calculate you water to fuel ratios and run the correct nozzle to ensure you are running a safe system.
but yeah decent systems are priced around the $400-$500 mark.
HI MAFIA,
PAYING OVER A GRAND FOR A WATER/METHANOL KIT SEEMS A BIT EXTRAVAGENT!
DID A BIT OF RESEARCH ON THE NET TODAY AND CAME UP WITH THESE ONES AFTER ABOUT 5 MINUTES...
http://www.rx7store.net/catagory_s/89.htm
There's a few cool kits there - hell we're talking about a high pressure pump, nozzles, lines etc etc - should be able to come up with something a bit more affordable. These guys sell a kit with a computer controllable water mist controller too.
Cheers
Here's the cooing mist controller:
http://www.rx7store.net/product_p/coolingm...0controller.htm
Edited by gtst25
bit of research hey?
Did you stop to check and see if those prices were AU or US..
They look to be US to me....
So double them all and they seem to be higher than what I am trying to organise. Those kits are also the same as what I plan to get.
The system I am looking at - Comes with all the bells and whistles...
Guest
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
