Hi Guys. I'm interested in starting a group buy because I want to see if I can get these water Methanol Kits any cheaper from our Australian Distributer. I guess the more the merrier.
Heres the good bits. (Taken from Snow Performance in the states)
ZeroDefects:
Sorry for the late post, I had lost track of this thread.
When tuning your engine for an A/F of 12.5 and using the the Boost
Cooler compared to a "Tuner Safe" an A/F of 11.5, you are replacing
10% of the fuel with the W/M. In boosted engines the amount of W/M
injected as a percentage of fuel is higher.
As a rule of thumb, the W/M will increase the octane rating of the
fuel by 25% irrespective of the grade of fuel.
So 87 pump gas you would be at 108
90 pump would be 112
93 pump would be 116
There would be little to no increase in octane from the W/M if race
gas like C16 was used due to the already high octane number of 116.
Best regards,
Dan
I would also like to add that a friend of mine has a 375rwkw kw Toyota Supra Running this exact same kit, and its awesome. We have shit fuel in mackay - 95ron is the best we can do, and all he could get was around 310rwkw on his setup (fmic, GT40 turbo, exhaust, 22psi boost, injectors and haltek).
Once the kit was fitted, it eliminated all signs of detonation, and he wound the boost to 28psi, and heaps more timing, and then 375 rwkw. All on the standard supra bottom end (they are forged from the factory)
He measured 100hp (60rwkw) gains, and I am assuming that if you run the right setup and tune you car properly, you would manage a good power gain. I don't think you'd see as high as him though unless you are running high boost.
There are other benifits
**cleaning your entire intake manifold, pistons, etc etc
**lower intake temps which is always a good thing.
** Ron Rating through the roof - Like running constant Av gas
** Costs about $6 a tank extra (cheaper, and about 10 times better than a bottle of octane booster) Distilled water is about $1 a litre at Supercheap, and Methanol is about $1 a litre. 3 litres does about 1 tank of fuel.
** Has optional safe guards if you run out of water meth)
Now I am not a pro, so I suggest you do some research on this, but its definately a good option.
More points -
** Water meth is only injected on boost
** There is a variable controller - which means you dial in a start boost, and a finish boost. This means you don't have one constant pressure (causing the car to surge when it comes in) it means you start off with light water and the pressure increases as the boost and load increases. Perfect.
** There is a saftey system (optional extra worth the $$) When the water run out, or the pressure drops from a blockage, the saftey systems opens up a solenoid that reduces your boost to whatever your wastegate i sset to (mine is 7psi, I run 16 psi max)
I have no idea on price but will update you guys when I get it in the next few days.
Hope people are interested!
here are the sites to look at if you are interested
http://snowperformance.net/products.asp?id=1 (there is also a forum)
http://www.full-throttle.com.au/Engine/Boost Cooler.htm (where I will be getting them from)
These are the options I will be getting -
*Boost Cooler Stage 2 Kit With the Variable Controller (comes with a 220psi pump)
*Solinoid Upgrade - Stops gravity Feeding
*6 Litre Reservior
8Fluid Level Switch Upgrade - Indicates fluid level.
*Safe Injection™- boost/timing reduction system for use with the Boost Cooler® water/methanol injection system promises to revolutionize the industry by providing for safety even with the most aggressive tunes.
*Wastegate Solenoid Upgrade - Solenoid such that boost is reduced in a wastegated turbo set-up.
Watch this thread for pricing (will be around the $1300 mark) and open times and close times)
Thanks guys
I've done a group buy before and I'm fairly well known here. I will not rip you off...
anyway. Let me know your interest!
Edited by The Mafia
yes it does, but you don't have to fill the water meth tank up exactly at the servo..
Just fill it up every weekend or something like that. As long as the tank has fluid in it the system will work fine. If it runs dry, stay off boost.
Also, bare in mind that its only misting water in during boost, so if you stay off boost, you aren't using it..
Also, these systems don';t do anything if you don't tune your car to them. If you have your car tuned with a shitload more timing and different afr's and you de-activate the system, you're motor will go "snap crackle pop" and then go bang.
its more of a permanent fuel improvement solution.
I'm going to whack one in, tune it to 91ron fuel (which would bring the quality of fuel to about 110 fuel) which would be like running avgas all day every day for $1.00 a litre (or whatever 91ron is these days) plus $6 a tank for the water and meth.
Apparently normal tap water can even be run through it without a problem. I might ever try it. If you use clean tap water (or even rain water) you'd save $3 a tank, meaning it would onl cost you $3 a tank extra to run avgas quality fuel in your intake.
I know its a high setup cost, but once its in....power...stability...engine longevity..etc etc..
Edited by The Mafia
This sounds interesting indeed... I run 98 RON fuel, this would jack it up to 110RON +
Question is; has this system been tested thoroughly by your mate? Interested to know what the full setup looks like, what components are included, and ultimately the cost involved.
pretty intersted mafia,
just a question, do you put the water and meth straight into ur fuel tank?
would like to see some photos of the setup, install in a car, and also like to know is it something i would be able to pull off or would i need to take it to a workshop to install
My mate says its one of the best kits he's seen, and he commented quite a bit on the jet saying its very good at misting the water (the finer the mist the better) and its much better than some of the other jets he's used.
My mate has been running for over 6 months now, has been able to run 7psi extra boost, and about 7 degrees more timing on full boost (thats a lot of timing) and the car went from 310rwkw to 375rwkw. He did a compression test and the result were the same after 6 months.
Definately been tested thoroughly.
' date='2 Mar 2006, 03:31 PM' post='1990752']
No, the water meth kit has its own reservior. You mix the water and methanol together (50\50) and stick it in the reservior. Then the varible controller has one of your boost lines attached to it - It starts injecting water in at the boost you set it to start at, and then increases the pressure in a scalar fashion to your maximum boost setting (to prevent choking). There is a 220psi pump involved, and a few little things inline to the jet.
The Solinoid stops the water meth syphoning when the manifold is on vacuum, and the reverse check valve stops the boost blowing the water back up to the pump.
You fit the jet 500mm from the throttle body (to give it a good distance to mix and mist) and then done.
I'm pretty sure you could fit most if not all of the kit yourself. It comes with full instructions and everything you need to fit it.
This only thing you'll need to pay for after the kit install is the tuning. (I'm going to tune it myself, I seem to know what I'm doing...lol I hope)
I could be interested in one too.
These kits are universal? Or model specific ones need to be made up?
When u say the jet should be positioned 500mm form the throttle body, i assume thats on the pipe connecting to the throttle body? (somehow i think that was a dumb question, but had to ask it anyway >_< )
i purchased a kit from cooling-performance a month or 2 ago.. It was about $400.. i found most were about $350-400.
I havnt put it on my car yet as my cars getting some other work done first, but i'll slap it on in the next few weeks and post up the results.
yrs ago i was running a turbo holden 6 at speedway we made our own meth injection system all we used was a washer bottle and motor with a small one way check valve connected up to a hobbs adjusable preasure switch and just plumbed it in b4 the throttle body .we did nor tun any more boost we used it to controll knock and it fixed that prob no worries some of you smarter guys could make ya own systems really cheap prob under 80 bucks if ya sit down and think about what ya actually get for ya money in a 400 buck kit
cheers midlife crisis
yeah thats true, i kinda regret spending $400 now. With me though id prefer to buy a tested solution then to sorta stuff around with it myself. Just cause theres potential to screw something up bigtime.
The actual mechanical components are very cheap and easy to buy/make. The problem with water injection as always is the engine safety aspect. What happens if I run out of water? What stops the engine filling up with water, hydraulic lock is not a pretty thing? What stops me injecting too much water and it getting into the oil? What happens if the pump fails because it is not designed for methanol? etc etc
That’s where the value of a complete kit comes in. They have the one way valves and solenoids to stop hydraulic lock. They have warning for low water levels. The have the sophistication and programming in the control circuit so you can adjust the water flow using the AFM signal or the MAP sensor signal. The pumps have sufficient power to mist the spray against the boost pressure (150/220 psi is heaps of pressure) and internals designed so as not to corrode when in contact with methanol.
:D cheers :laugh:
:D cheers :laugh:
well back then you could not buy one of the shelf the one way check valve stopped any hyd lock probs we had a light connected to a float to warn of low meth water we only used to fill it once during the night at the start of the meeting dummm speedway holden 6 to to many electronics to worry about all im saying is this is not a new idea i was doing 20 yrs ago now there are complete kits well thats great news for non thinkersbut the same princapals apply today as then and if i was going to use one i would still have a go first never had a washer pump fail and the nozzles we used to tap into the plenum was actuall ma gee or endleee machanical meth nozzles this wasent some half baked things we used we actually sat down done the sums and gave it a go .and i can say the 4 or 5 seasons we used the system it worked great for us
the most expensive part of the kit is the pump. a good 100psi shurflo pump will set you back a few hundred dollars easy.
all the other stuff is realatively easy and cheap to obtain.
one thing that people have to remember is not to just buy any old kit, you need to calculate you water to fuel ratios and run the correct nozzle to ensure you are running a safe system.
but yeah decent systems are priced around the $400-$500 mark.
HI MAFIA,
PAYING OVER A GRAND FOR A WATER/METHANOL KIT SEEMS A BIT EXTRAVAGENT!
DID A BIT OF RESEARCH ON THE NET TODAY AND CAME UP WITH THESE ONES AFTER ABOUT 5 MINUTES...
http://www.rx7store.net/catagory_s/89.htm
There's a few cool kits there - hell we're talking about a high pressure pump, nozzles, lines etc etc - should be able to come up with something a bit more affordable. These guys sell a kit with a computer controllable water mist controller too.
Cheers
Here's the cooing mist controller:
http://www.rx7store.net/product_p/coolingm...0controller.htm
Edited by gtst25
bit of research hey?
Did you stop to check and see if those prices were AU or US..
They look to be US to me....
So double them all and they seem to be higher than what I am trying to organise. Those kits are also the same as what I plan to get.
The system I am looking at - Comes with all the bells and whistles...
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
