I had my clutch changed to an exedy heave duty clutch about a year ago, and pretty much since then it's made a funny squeeking noise when disengaged (pedal not pressed). It is a bit intermittent, but is usually there. It sounds like a cricket and if I press lightly on the clutch pedal it gets louder and softer, so i can actually emulate cricket noises if I like.
Does anyone have this problem? i think i remember asking someone this before, and the reply was that this sometimes happens with the heavy duty ones. (Is this something to do with the pressure plate? I remember reading everyone saying the throwout bearing is the suspect one, but mine appears to be happening under diff circumstances..)
I don't think it's dangerous or anything, but it kinda defeats the purpose of looking good in a nice car, that sounds like cricket trying to mate!
i would think its your trust bearing mine did the same thing when foot is off the clutch it sounded weird i guess like a cricket ??? :laugh: but when i depressed my foot it stopped... if that is what you are referring to i would replace the bearing if it bothers you other wise dont worry about it.
leech_ & FSTR32 - the issue he's talking about is different..
when he pushes his foot in you can hear it squeak..
mine does it.. plus a lot of others cars..
do a search - someone else had a thread on this..
amuses me when i'm in traffic.. sounds like someone's rooting under my car on a squeaky bed.. ;)
if its a squauky noise you hear when u engage and disengage the clutch, then it could also be your clutch bracket. This is generaly because the spot weld on the bracket is becoming loose. i have allready had to get my bracket re welded and i think its going again.
  • 8 months later...
yeaa my 32gtst had the same problem after 1 year of owning it, cricket noise huh , yea thats a good wat of describing it as i dunno how to describe it to mechanics haha, i said sounded like a disc spinning. If i were to fix it , how much would it cost ?
Have to be careful not to spray it all over the clutch plate..Any liquid lubricant isnt good for a clutch.. Id have to say its got somthing to do with you throwout/thrust bearing.. A worn bearing can make some pretty strange noises. Either that or is a bearing in the gearbox..
Edited by Godzilla32
could be thrust bearing, or it could be a real cricket. Go to a pet store and buy some spiders, preferably a huntsman style and put them in various locations on the car. Also works well for car security.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
