Yeh you will get 400-450km/55L, which is almost the same as what you will get in a gts-t. Rev it out at every single lights and that should drop down to around 350-400km/55L (for a stocker)
Modify it, and drive it like you stole it - expect 200-300km/55L
What model do you have R32, R33 or R34?
I had a 33, and the only time I was getting 450km+ to a tank was when it was in Limp mode ie, 6psi boost or something silly like that. Or H'way driving could yeild those sorts of results. Around town though forget it, 400 was the best I could do. I only had a full exhaust (turbo(s) back) and panel filter, still running stock boost and ECU. Probably could have improved that number with a PFC as with the exhaust it started to run quite rich.
TommyK had a 33 I do believe. . . .
OK.... If you say so....
How many GTST's are there running in the 10's?
I read another thread where you said you were going to run a 12.......now it's a 10.
I might go to Willowbank next wednesday and run a.....hmmmm....let's see......10 sounds like a nice even number.
Realistically I reckon you are looking at a mid to high 13.
Feel free to prove me wrong :D
Thats harsh Warwick...
Man you know nothing about me...
You most certainlly dont know anything about my car...
I have run an official 12 second pass (even if it were a 12.95). I have run out of puff... There is an Autobarn sponcered R33 GTST in NSW which ran a 10.6 at WSID in November last year with a TD06 turbo kit and 700cc injectors... This car had stock internals also...
I have produced the goods and done all the supporting modifications to make my car able to make 10 seconds more than once... Unlike the autobarn car...
I just have not the $$$ to do the turbo kit atm so i decided to do the injectors and plenium first... My internals are completed now and cams are on order also...
I have no doubt i will run a high 10 once the turbo kit has been installed and tuned as it has been done before and well documented...
Thanks for taking the subject off topic... But i needed to explain my reasons for my 10 pass line stated on the previous page.... You disapoint me Warwick as I font know you nor you know me and yet you find it neccessary to attack me on a public forum...
I thought it would be a good idea to state my fuel economy and give a reason as why its so poor. So i can cheer up all GTR owners... LOL
Back to the topic: GTR Fuel usage
Col, my apologies.
PM sent.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
