:burnout: Im bringing my old school skyline back from the dead
now i know these days R32 R33 R34 are the rave for the skyline models but i like the old one cause you don't see as many around and when done up they look nice
NOW i want to know i got a 1981-82 skyline i want to know what sort of make R30 my car is
i want to keep the motor as is but put little add ons to help with performance air filters -fuel- etc anyone got more info on these kind of mods i don't want to turbo the car it's got plenty of power for a 20 year old car it runs with holden 308's easily but i want to put a rear wing and a front bar on it and stuff so if anyone got some more info for us i would like that thanx to get my beast i got totravel from brisbane then head towards canberra to get it ?
i sold it to a car yard 3 years ago and it's been there since the bloke nearly tripled the price and now it's back to the price i sold it for so im grabbing it while i can?im from brisbane and once going i want to meet up with some of you's skyline fans any chance of that ?:shake:
https://www.sau.com.au/forums/topic/10871-old-school-skyline-for-me/
  • Replies 57
Guest nismogtsx
The old school DR30 or R30 as know by some are well know for the FJ20 motor.... The old school 2.4 litre 6 is pretty gutless in compairison to the rb series of motors....
Plus they are very, very expensive to fix... I worked on one onc for a customer back in my auto-electric days and we ended up charging over $1400 for a basic re-wire.... It turned out to be my biggest night mare.... Those cars when in good condition run well.... But after 20 years the wiring gets a little tacky...
basically the wiring is good motor might need attention cause it has sat for so long and i'll be getting it back to how i had it
it's all standard but a few little mods , a few more and a reconditioned 2.4 ltr and i'll be sweet again?
maybe in the near future i might do a motor swap for something with turbo or nos or supercharged who knows with all the options?
Hi hoon69 I own an '84 R30 hatchback. I modded this car with a passion for 5 years. Then a couple of years ago some scumbags decided it was their turn, came back from a swim ..... empty space. Sh_t and the new tyres were still on my account. Got a call from the cops 3 days later. Cars a write-off, nose first into a drain. The wreck has sat in a shed since then waiting for me to do something. As I've recently bought an R32 GTS-t I don't know if I should wreck it, sell it complete or transfer all the good bits to an R30 sedan that I bought for that purpose. Mods include L28 2753cc P90 head engine with hi-lift cam heavy-duty valve springs, cold air induction, custom extractors, S.S. 2.25" exhaust, DYI quickshift, altered G/box ratios, R200 diff, O/size half shafts, DR30, front disc and calipers, konis all round, -40mm kings springs (front), nolathane bushes, revised lower arm mount points, adj. castor rods, F & R strut braces, nismo front seats, $5K stereo with 400 hour self install, round tail-lights, plus dozens of nice touches and reconditioned parts. It was a good ride while it lasted. If you are interested in the car or just want info on specific mods please P.M. me or post here.
Stang, BOoStEr here. Stock RB30 powered R31s made 118 KWs ,GTS1s 130 KWs, GTS2s 140 KWs The GTSs had nice S.S. extractors, exhaust, cam, head and ecu mods. I have an RB30 ecu with a Chiptorque programmable chip in it. It is currently programmed to suit Chiptorque spec. stage 3 camshaft , O/size throttlebody, H.M. headers and 2.25" sports exhaust. These mods are good for 140 KWs+.I might sell these parts minus the exhaust (to suit RB30 VL). Problems I,ve encountered in aussie R31s--- noisy diffs (premature gear wear),crank angle sensor (usually dirty connector plugs or degree wheel in distributor). Any questions just P.M. me or post here.
Stang, I'd be guessing a bit as prices vary a bit from place to place. Value dependant upon condition moreso than age.
A series3 may bring $1000 or so more than an early model in the same condition.
GX,GXE $2000-$5000
Silhouette,Ti $3000-$7000
GTS1 $7000-$11000 (only 200 made) Lots of fakes
GTS2 $8000-$12000 (only 200 made) " " "
Genuine GTSs have a numbered badge on the glovebox.
As a collectors vehicle a vendor may feel justified holding out for a
higher price for an exceptional GTS.
darkhalf, S.S. is stainless steel. I'd bet the SVD extractors had more R & D than the hurricanes.
Stang You don't want a locked diff on the street. They are only at their best on the dragstrip or on a dirt track. If they are done properly they are stronger but suffer a lot more stresses on corners. If you are worried about the aussie diffs you could always buy a jap HR31 instead and get IRS and LSD.They have a tougher diff and are usually a bit cheaper than an aussie GTS but they only come as coupe or 4door pillarless.
BOoStEr
duh! thanks !!!
thats what I thought until I swapped them over from the hurricanes on my GTS 1 engine. lost a bit of power because of the port size difference (smaller than the ports in the head). now im shaving the GTS extractor ports to 36mm cause i got my new exhaust fitted to these extractors last week :D
Stang, It's too much trouble to fit the jap independent rear end to the aussie R31 as these all had Borg Warner solid axle rear ends like the VL. I've heard people say they will try but I've never seen it done. If drifting was the only type of driving ever used then locked might be a cheap way out but a good LSD is always worth the extra money. A good diff place should be able to recommend some tough internals with LSD for stock aussie diff housing.Make sure you get lower than stock ratio(3.7:1) if you want to drift eg. 4.1:1.
Maybe we should apologise to hoon69 for 'jacking his thread.
hoon69 If your Skyline is an MR30 with the L24E engine a good set of extractors and a 2.25" sports exhaust (get rid of left to right tail pipe extention) will help a lot. Get rid of the airfilter cross-pipe and duct cold air through the radiator support panel into the top of the airbox and replace the std filter with a K&N panel filter or similar. Get good plugs and leads and make sure the distributor is in good condition. Beyond this further mods require more money than you should probably spend on this motor. The L-jetronic computer is the old analog type and is very inflexible.It requires electronic tricks to accomodate any mods.if you really want to make good power out of this motor you will need a programmable ecu. Then you could make a custom inlet manifold, do some headwork, cam, and raise the compression. An L28E bolts straight in and looks stock and has another 360ccs. how far do you want to go?
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
