Just wondering. i was thinking of giving my car a nice glossy black/metallic if i could, just wondering how much will that cost roughly, but also i was wondering if it would be better if i get the body kit put on first before the respray.
https://www.sau.com.au/forums/topic/108736-re-spray/
  • Replies 106
Posted Images
having the body kit on already saves colour matching for the re-spray.
not to mention its cheaper because you dont need the whole car painted, then additional body parts.
best way to get a accurate price for a respray is to ring around. :)
saves being told it cost $x when really it is $y.
https://www.sau.com.au/forums/topic/108736-re-spray/#findComment-2004034
depends on your body kit, if they are fibreglass, they cannot go into the oven, gotta wait till paint to dry slowly..abt 1 week, hoping sunny weather.....
it'll be quite fast for the rest of the car, if they are oven baked...well done...yummy...
I want pie!!
https://www.sau.com.au/forums/topic/108736-re-spray/#findComment-2013620
if you want a real qual job there is a place in malaga that uses house of kolor paint. some of the things he has had come out of there are nice...
his name is ryan... cant remember the name of the shop tho sorry.
(but it wont be ya cheap 11-2k job i would think, plus metalics cost more and yeah as gazza said its gotta be rubbed back etc if you want it to look good)
https://www.sau.com.au/forums/topic/108736-re-spray/#findComment-2013966
dont bother with flake paint, i have it on my car and its more trouble than its worth.
it also costs a fortune cos our car has the base colour (black) then 3 layers of flake with 9 layers of clear.
its extremely time consuming to look after and its hard to colour match if ur car gets damaged. ours is causing a lot of hassles as we have to get our boot replaced and repainted and we dont have the mix details....
https://www.sau.com.au/forums/topic/108736-re-spray/#findComment-2016348
lol go the metalic but make sure if ya get anything custom you get the mixes written down somewhere you can find and that way you wont have the same issues as rhianne i guess...
either way its gonna cost ya a nice pocket or two so just make sure what ya pic is what ya want lol
https://www.sau.com.au/forums/topic/108736-re-spray/#findComment-2018682
yeah but different sprayers paint cars differently so i highly doubt itll ever look the same as the original.
i own the title of shitter with glitter! i made it up haha (my car really is a shitter!!!)
i rekon go metalic black, should look hot!!!
https://www.sau.com.au/forums/topic/108736-re-spray/#findComment-2019743
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
