  • Replies 106
Posted Images
Any one know the amount of colour coats and then clear coats on the GMG R32 GTR out of the factory? I know the colour is Nissan's KH2, but I have a body kit in mind and want it fitted after spraying and also want the bonnet resprayed to match the cars exact colour.
Also, what would it cost to get a kit + bonnet resprayed? I will probably take my car to damage control because I have some rust that I want them to clean up for me as well.
https://www.sau.com.au/forums/topic/108736-re-spray/page/5/#findComment-2317132
  • 1 month later...
5500 it is going to cost me to get my car dont by fibre vision, going with black, red pearl, and gold glitter. i guess i am paying most of it by labour, cause of the colour i am after and this is just the out side of ther car
https://www.sau.com.au/forums/topic/108736-re-spray/page/5/#findComment-2446514
thats reasonably 'cheap' for what you are having done.
not having the door seals/engine bay/etc etc done?
i was going to get mine done in calsonic/bionic blue, before i decided to sell it, was looking at about $7,000 for that, but i *know* that would have been a good job.
https://www.sau.com.au/forums/topic/108736-re-spray/page/5/#findComment-2446690
  • 3 weeks later...
umm depending if you have had any past experiance and how confident you are. could do the prep work your self, such as getting the car primed up and everything, takes a while and your car while look funny for a while but it really cuts down man hours therefor taking a huge chunk out of the cost,
me and my mate worked on priming his hilux mini truck every weekend, took a while but that was because we were shaving door handles etc.
it is time consuming but the longer you take to get the primer on there right and sanding it back so its 100 percent perfect the better finish you will get.
this is my mates car preped and when he got it sprayed >_< hope this helps, if it doesnt then shoot me >_<
https://www.sau.com.au/forums/topic/108736-re-spray/page/5/#findComment-2500336
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
