  • Replies 70
Posted Images
For Wrecking, Nissan Skyline GTR R32 1991 model.
Parts that are already sold or NOT AVAILABLE are:
Complete Chasis (Shell)
Exhaust
Bonnet
Boot Lid and Wing
Headlights/Blinkers/Parkers
Grill
Taillights
Front and Rear Seats
Complete Dash including intruments and shrouds
Still Available:
Complete Engine/Gearbox/Running Gear including FMIC
Suspension
Front Bar/Rear Bar
Guards
Weds Sport Wheels
Trims
Doors/Windows/Mirrors
Interior Bits etc
Also avilable 2 x Chipped R32 GTR ECU's/Blitz Iridium Sparkies/550cc Injectors x 6
Get in quick. Please call me (NOT SMS) on 0413 346 841 for availability, details and prices as I'll be busy stripping down the car and won't have much time to check the forum.
pls check your PM - interested in the injectors
Could I please have a price on the engine inc electrics and loom no ECU. Also all the piping for and Intercooler and Bov's. Pretty much the whole engine/piping/electrical associated front part of the car firewall foward to make the engine run. A front cut goes for $5000 remember and you get a g/box. See spool imports web page.
How many point is the roll cage and how much also.
Hey, how much for the door trims???
Will they suit perfectfor a '94 model R32 GTR?
Any pics, and what condition are they in?
email is [email protected]
VERY Interested!!!
hi there,intrested in ur Diff,should fit my gtst,would you know??how many K's??any play in it??would you be willing to ship to Alberta,Canada??much appreciated..oh and how much??..ha.thanks!
the roll cage is a full complet cage from rear to front not sure how many point as for the front cut please call me on 0413 346 841 for further chat thanks champ or leave ur number
hi mate the diff has 119000klms and it is a good diff in order to fit the diff in ur gts-t u need the cradle as well with out cradle it wont fit the price is $650 diff and cradle $250
VERY Interested!!!
the door trims will fit perfect but im not sure if thay will match ur trim that is on ur seats as for the trim meterial changed over the years thay are in good nik i will take pics for you if ur interested price will b $70 each any questions call 0413 346 841
  • 4 weeks later...
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
