we are both with Node, on ADSL 1.5Mb .... unfortunately we both live in Northgate, so our phone lines are on a RIM, hence we can't get ADSL2 or + ;):);) ;)
Well that just plain sucks..
Internode here.
1500/256 40Gb/month.
I DO need to do some cleaning out of things.
hehe yer that or nodes premium usenet pron service. :(
Cheers Howie.
lol, I expect to be using my PC a fair bit over the next 4 weeks during recovery; go BF2.
might try overclocking the unit (p4 3.4, gigabyte mobo, 2gig ram, 7800gtx, raid 400mb sata HD, 9 fans) to 4000, havent gone past 3700 (8%) as yet but its been real stable and heat hasnt been a real issue
:P
get a nice fan and u will easily see 4ghz stable
Nice Fan
I went for a Thermaltake Blue Orb 2 (about the same price) and it is quite unbelievable - it is absolutely silent, is on automatic speed (ie. the hotter the CPU gets the faster it will spin to try to cool it down), and the hightest speed I have seen it go is 1,200rpm (still silent) and the hottest I have seen the CPU is 45 degrees when hammering it. Currently it is 23 degrees ambient, 39 degrees CPU at 830rpm .... quite unbelievable for a dual core X2 4200 @ 2400Mhz (4600+ speed).
Lik-Sang were an import export company of videogames. And in the past year or two sony have been sueing them and they have finially had enough and probably can't afford to keep fighting these battles.
Go to www.lik-sang.com if you want some info.
In other news i got to play the Nintendo Wii tonight and it is so damn good it's unbelievable. It's so fun using the remote and the online functions are awesom and well thought out.
Everyone should be pre ordering one.
December 7 $399 and you get wii sports. Which has 5 sports games in it.
So good.
P.S buy my R34 so i can get a V35.
I saw the black V35 coupe that Synergy brought in for their compliance (that I posted some photos of a while back) driving on North east Rd the other day .... unfortunately it was going to other way so I only got a quick flash of it. *drool*
If I had known how soon V35 compliance was to be available when I bought the R34 last July, I would now have a V35 in my driveway instead of the 34 .... but I had committed to buy the R34 when I found out :) .... bloody fantastic cars (if not very lacking in power) - even Jeff from C-Red owns 2 of them and absolutely raves about them!
I couldn't work out why I couldn't beat Steve's score - all I could get is 35.5 seconds - but then it occurred to me that SuperPi only uses 1 of my 2 cpus (dual core you see) :P
A more appropriate Pi test is the multiple core version here: http://www.hwbot.org/download/multipi-0.2.zip
I got 1 min 23 sec @ 2.75Ghz - that is the highest I have overclocked it to so far .... I will get it to 3Ghz when I have some more time to play with it! (For some strange reason the multiple core beta starts time at 30 minutes rather than zero - but I assure you it is not true! lol).
Everyone post up their scores to compare!
to get super pi mod to utilize dual core u need to run 2 instances of it from to different named directories, then u can task manage the ifinity of CPU's to each program executable
i also dont understand the program u used i ran it any way
Running Stock
Running 4ghz
Super Pi 2 instances Stock
Super Pi 2 instances 4ghz
Steve I am pretty sure the program I gave the link to calculates Pi to 4M places, and utilises both cores to do it. When I calculate SuperPi to 4M it takes 2:42 with one of my cores, and that program takes 1:17 (now I have upped my clock to 2.925Ghz *and it is still stable* - that is equal to an as yet unreleased X2 5800+ :rolleyes: )
oooh yeah I just benchmarked my CPU in Everest Ultimate Edition "CPU Queen" and topped the list - eat my dust overclocked Intel Core 2 Extreme 6800 @ 2.933Mhz - my beastie at 2390.5Mhz kicks your butt :P
And for those that play CS:S go do the stress test .... I got 146fps with my XFX7600GT @ 1,280 x 768 4xAA :rolleyes:
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
