lol yes it was EOI.
And there is plenty of it.
The back room here just isn't ready yet.. I've got exams on so I'll get my arse in to gear and rig up some secure tables that span around the room. :rofl:
Power is the next issue.. Unsure if a single 15amp feed out to the back room that also powers lights to be sufficient. :S
yeh, should be ok, i mean, 6 computers with monitors no problem, 7-8 pushing it, id think about getting a long extension cord from another section of the house to power any more than another 4. 12-16 people is the sweet spot in numbers anyway, less its boring after a while and more its to much trouble. get every1 to pay around 15-20 bux for power and food/drink for the day and BYO alco.
In the mean time if any one runs in to a sparky ask him how many pc's he thinks its safe to run off each power point. i.e power boards. :S
I've got 6 dual outlets in the same room.
Obviously we will need a pair of headphones each also. :P
yeah I would have thought 6 PCs per power 'zone' .... normally you would have 1 zone per section of the house (most houses have 3 zones), and likely all of the 6 power points in your rumpus room would be on the same zone. So what you do is run an extension cord from the complete other end of your house, so you get 2 zones of power to use.
When we built our house I got the sparkies to put 3 different zones to my rumpus room for this exact purpose .... then I went and ruined a perfectly good LAN room by putting my beautiful pool table right in the middle of it :dry: .... I also have 3 zones of power in my office for the large number of electrical devices I run in here too :P
Well a power board can supply what 2400 watts can't it 240x10 and your average computer would use ~350W tops and a 17" LCD uses ~40w so that works out to roughly 6 PCs.
I may be completely wrong though
my pc uses 3 case fans, the psu fan running, watercooling pump, and 2 external fans on the radiator. The psu is a 550W antec jobbie + a 20" widescreen, so a couple more newer pcs would blow the power usage right up...
Edited by Bl4cK32
Hey Madaz,
this is the stuff that i am doing. At the moment this is only 69000 polys and my computer is starting to struggle with it.
i'm not sure if its only my video card that need up grading or more
I have a gig of ram which helps, The video card is only a 128mb ati radeon 9600.
got a 2.6ghz cpu
any suggestions?
No mate, starting to do it proffesionally (paid woohoo) now and just need a bit more power to help run smooth. The model in the pics is only 60pixels long I just need something that will stop it running jerky when doing the fine details
With regards to how many pcs you can run off one powerpoint, wouldn't that have something to do with how many amps each is pulling? Powerboards usually have a 10A fuse, regardless of how many outlets...
Is it possible to measure how many amps an average high-spec'd pc draws and use that to work out how many could be run safely off a single powerboard etc? I presume powerpoints themselves also have a limit to how many amps they can provide? dont know enough about the electrical side of things to go any deeper into it.
its also worth noting that a 350w power supply means 350w MAXIMUM (or "safe" maximum? before its likely to fail). It would normally run well below this amount, obviously depending on how much of the system you're using at any one time. I think the biggest power drawers are your video/tv cards and drives...from memory (used to be a tech years ago).
plus I only have 2 pc's (running off separate powerpoints) so no problems at all. :)
good luck with the "lan party" :)
    • I know -_- Oddly enough I went to a car show this weekend and not a single person made any mention of Nitrous... I did have to argue with a know it all that was convinced I had an RB26 head with HKS V-Cam as opposed to a regular VCT RB25 head, but what do I know. I think my HKS oil cap was throwing him off.
    • That seems like a lot more work than just using a second jack under a front tow hook to raise it enough to get another jack under it.
    • They're wonderful when only used to lift your car up an inch so a real jack fits under your front lip. Besides that, I've only ever used them on the side of the road.  We call them widow makers here.  Unfortunately, like I mentioned in another post, ramps are not an option for me due to generally working on my car once my kids are asleep. Cold starts, 4" exhaust and sleep rarely go well together. I honestly find using ramps a hell of a lot more work than what I'm currently doing anyways.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
