Using the right tool he 'may' be ok with the majority of stuff as the previous windows xp install would have installed in roughtly the same physical position on the disk. Then the user would have added his personal files.
Run an undelete tool, see what you can get off.
Myself... I like to run 2 partitions. One for windows and programs and one for my docs and other crap.
Re-installs are then hassle free.
  • 4 weeks later...
Imageready in Paint Shop. Hmm... didn't think to have a look at that app. Thanks :)
I have a mate thats into all the Paint Shop Pro stuff. Might have to hit him up on it.
$99 good work :worship:
Ok, my work pc is giving me the shites (well, headaches anyway)
Pentium 3.2 with the standard L775 fan
The fan has gone bonkas and is SO loud. How do I replace it? I cant see how the fan comes off - do you actually need to take out the motherboard to get access to the back side of the MB to undo screws that hold in a L775 P4 fan?
Im a bit lost as to how to take out the standard fan.
i hope this help isnt too late
the top of the circle has a slot to put a flat head screwdriver in it from memory u turn anticlockwise to take the HSF off you will need to do it too all of them... you will know when youve got it right
mine looks a little different because its not OEM fan anymore
cheers lads......... nuh not dusty, nor will I be spraying silicone into the MB of the sole work PC. Ive got the exact same fan at my home pc, both 1yr old, and both making an 'off centre' spinning noise - dropped a bearing ? ? ;)
got a 'golden orb' big arsed copper fan to replace one of them (probably the work pc first, then look at mine at home)
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
