My computer randomly shuts down for no apparent reason either.
It's either motherboard or cpu as i've i've tested everything else.
I hate pc's as it means to fix it realistically i need new RAM, motherboard, and cpu, powersuply
It never usually happens to me but I have noticed that upon new OS install it does it maybe 4-5 times then it becomes completely stable, it must be patches or something that fixes it.
I am now running 64bit winxp pro and I must say significantly quiker than vanilla xp pro.
Well i seem to of fixed my wireless woes.
I got another wireless adaptor. A linksys one.
I now get excellent signal strength and no dropouts what so ever.
Also my computer seems to boot in half the time and is more stable.
I'm guessing that the netgear wire;ess adaptor just didn't agree with my hardware and/or drivers.
Everything was up to date, including firmware on everything.
Ohh well all good now.
Also fishpaste someone from your work rang me today.
Do you guys have any games in stock at all? or is that not really your area?
someone is pulling some kinda random insurance job thing and wanted quotes on crap
have to ask the boss about games, we normally get copies of the new big titles when they come out, but other than that, we dont get much demand for them
nice score Chops
I gotta say that Im *finally* happy with my Xpertvision 2900xt 512mb from MSY Adelaide.
better performance and quality in my mind then 2x 256mb MSI 7800gtx in sli mode
.......... just awaiting my Vista Ultimate I scored for under $250 on ebay and Im set :)
LOL
hahaha oh well, atm my broadband is so bad I cant even access this webpage at home.
churning to Internode as we speak.
never mind, OEM Vista Ultimate 64-bit for 235 + delivery, guaranteed new and unopened. saw it in harvey norman for $700 odd
crazy
my current XPpro is a dodgy copy. so I guess its time to do the "right" thing
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
